Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic 2nd light to the left (ON RED LIT)
Help! The second light on the left on the last few versions oc Saeco Madic deluxe is steadily lit in red.. What am I supposed to do?
  • 3 Answers
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Posted on Jan 23, 2008
Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
Bean and Grounds Bin Lights Lit
Sounds like your boiler has gone, check for a fuse, replace, Otherwise you might have to take to Tech to replace parts :(
Jun 09, 2008 | Saeco Magic De Luxe Espresso Machine
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
The button all the way on the left is lit up in red!
the machine still work fine still descaling time with descaler not vinegar .vinegar no good descaler melt calcium follow what mark on the product to descale to reset the light i think you have to hold the steam button for 10 second thanks for using fixya pierre p.s im gonna double check how to reset the light ill get back to you
Feb 22, 2008 | Saeco Magic De Luxe Espresso Machine
2nd light on the left is steadily lit
descaling time to reset the light i think you have to press the on buttom for 5 second if it doesnt reset let me know cheers
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic deLuxe Central Unit Light is steadily on...
Central unit should almost "snap" into place, gotta push hard, maybe not all the way in.
Dec 29, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - trouble light on
Not sure which light you are refering to because the far right light shuld be temp ready light. The one you describe slunds like the descale light but that shouold be second to from the left. In which case it is telling you to descale. I can't attach a manual here so do a search for saeco repair and an authorized repair center should be able to get you one.
Aug 09, 2007 | Saeco Magic De Luxe Espresso Machine
Motorola H700
First, you will need to put the H700 into pairing mode. Look at the last digit in the part number for your headset (there are 3 versions). If it "A" or "B", do the following... 1. Starting with the headset powered off (flip closed), hold down the Call button for 1 to 5 seconds until the light is steadily lit in purple. 2. With the light steadily lit, flip out the boom. The light should remain steadily lit in purple. If the light is flashing, or if the light starts flashing anytime before completing the steps below, the headset is not in pairing mode, and these steps will need to be repeated. If you part number ends in a "C", do the following... If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple. If the headset has previously been paired with other devices, first ensure those devices are turned off. Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple. And finally, you will have to follow these instructions on you A900... 1. While in standby mode, press the Menu/OK button 2. Select Tools (9) 3. Select Bluetooth® (4) 4. Highlight Yes, using the navigation keys, on the Enable Bluetooth® prompt 5. Press the Menu OK button to enable Bluetooth® 6. Select Bluetooth® (4) 7. Press the left soft key for Add New 8. Highlight Search, using the navigation keys 9. Press the Menu/OK button to begin search for new device 10. Highlight the desired Bluetooth device, using the navigation keys 11. Press the left soft key for Add to List 12. Enter Passkey "0000" press the Menu/OK button, you will get a brief message stating pairing 13. Press the left soft key for Done 14. At the Trusted Devices screen, press the left soft key for Connect 15. You will get a brief message stating connecting 16. After being connected you will return to the Bluetooth® Trusted Devices screen Hope this helps. Good luck
Jun 24, 2007 | Motorola Mobility H700 Wireless Headset
Saeco Magic De Luxe Espresso Machine Logo
516 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
