Question about Denon AVR-2803 Receiver
Unresponsive remote I am having a problem with my Denon AVR-2803. The only responsive controls seem to be on/off and volume controls, I am unable to gain access to my System Setup. I have made sure that there are monitor cables connecting the Denon and the TV, I am using component cables. I have tried pressing all of the three shaded buttons at the top of my remote, then selecting System Setup. This seems like it should work as the button in grey lights up along with the learned/tx button at the top. I have also tried to gain access through system set-up with every function. I've even tried switching the batteries, resetting the Denon microprocessor as well as resetting the remotes learned controls. Essentially the 71 buttons that make up my remote limit me to adjusting the volume and turning the system on and off. Would very much appreciate help, thanks for your time.
  • dilucca Feb 02, 2008
    I am having the same exact problem. I have disconnected all other components and have tried hooking up the receiver to the tv through optical, coaxial, and s-video and still cannot get any menu set-up on the box. I think it is something to do with the HDMI signal not correlating to the receiver or something like that but I can't figure it out. Denon tech support is closed on the weekends so I'm out of luck until Monday - um, that's the day AFTER the Superbowl isn't it? *#@! It's driving me nuts! Anyone out there please help us!
  • st0bart Mar 19, 2008
    Exactly the same problem here. My remote is basically useless. I can see the channel/function displayed on my monitor (e.g. if I change from DVD to TV) but I can't get the system setup menu.
Had same problem with this reciever over the weekend. I had to hook up a TV to the COMPOSITE monitor jack and then I could see the menus. I could never get it to show the menu over the component outputs, however a DVD player hooked up played perfectly. Anyone have a solution?
Posted on Feb 18, 2008
I can't seem to get the tuner to work on my Denon AVR 2803 receiver.
It can't hurt.
You will lose all your settings though. So you'll have to set the amp up again from scratch.
Before you do initialise, let's just check.... You plugged in a FM or AM aerial, right?
Sep 13, 2014 | Denon AVR-2803 Receiver
I can't get a menu screen up on my Denon AVR 2803.
Did someone turn the OSD off on the menu? You might try a reset of the receiver. This would be in your manual.
Aug 23, 2012 | Denon Avr 2803 7.1 Channel 875 Watt...
AVR-2803/983: Had recent 24hr Power Outage. When power restored, I receive no video/sound from TV thru COMCAST HD box, no video from CD but do get sound, lost partial use of Zone 2. Zone 2 works if I...
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
Jul 16, 2011 | Denon AVR-2803 Receiver
Hello, I just hooked up our new PS3 Game system to our Denon 2803. Was happily playing it when it cut out on me after about 30 mins of playing. Turned the volume down to see if I was overloadingit but it...
looks like you are overheating it let it cool down for at least 20 min. and then when you use it just lower the volume, after that it should give you no more troble
Dec 18, 2009 | Denon AVR-2803 Receiver
Denon AVR-2803 Zone 2 sound source
You have to switch your remote into Zone 2 Mode. It will be an option on your remote. Once you put it in that mode, you can change the source just as you would Zone one.
Jan 25, 2009 | Denon AVR-2803 Receiver
My AVR 2803 shuts down when volume is at medium or above.
too big a speaker load,unit sensors shut unit down when speaker impedance gets too low . and draws too much current at hi volume.A bad woofer or tweeter voice coil burned by sudden excess volume can cause this,also partially shorted speaker wires.
Jan 03, 2009 | Denon AVR-2803 Receiver
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Remote control not working
Check the batteries first. I have seen remotes that the lights will turn on when you press a button. It ended up being the batteries.
If the batteries are good, do any of the functions work?
Mike
Nov 06, 2007 | Denon AVR-2803 Receiver
Denon Avr 2803
Could be bad connection. Try to tight connection cables on receiver and TV.
Oct 15, 2007 | Denon AVR-2803 Receiver
Denon AVR-2803 Receiver Logo
224 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
