Question about Lexmark X9350 All-In-One InkJet Printer
Incoming faxes are not received
Incoming faxes are not getting printed. The dial on the X 9350 is showing that the fax is getting connected, but the incoming message is not getting printed.
Outgoing faxes are OK according the the recipient at the other end
Please send me the solution on the email :
I am from Melbourne Australia - Thanks for your help , SAM
    Brigadier General:
  • 6,966 Answers
If I may add to hutchwilco...
This is not an uncommon problem to most AllInOne. A couple of things you can consider:
1. Verfiy that the printer can print, check the ink level. Also in some cases, the unit fails to recognize the optional tray 2 (if you have one installed);
2. Verfiy that the incoming fax number is not blocked (junk fax list & numbers);
3. Number/size of incoming fax pages too big, set to "Use Two Pages".
If the above will not work for you, you may need to do a:
a. soft reset (menu settings only). up/down on the control panel for "Maintenance", press the check, up/down for "Reset Defaults", press check.
b. full reset. This is done by powering off, simultaneously press green and red X buttons (Start & Cancel) then power on. This would erase all your settings and saved information.
c. uninstall the Lexmark software in your PC. A reboot is required before you re-install using the CD that came with the 9350. Do not use the auto detect/install of Windows.
Should none of the above be corrective, you may need to seek the services of your local Lexmark service.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 21, 2008
  • 37 Answers
1. Make sure you have paper in the feeder tray.2. Make sure that Fax Forwarding is not selected: Use the up/down arrow buttons to scroll through the menuoptions until you see the option required, and press the "check mark" button to select:
Select "Fax" on the device main menu. Select "Fax Setup" from the Fax submenu, Select "Ringing and Answering" from the Fax Setup submenu Now find the "Fax Forward" option. Once you see this option, press the left or right arrow buttons until you see "Off". Now press the "Enter" button to save.
Let me know if this doesn't solve your problem, and include further detail to the problem if available.
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Jun 27, 2017 | HP Office Equipment & Supplies
I have done fax text report, cleaned the head and everything has passed. Still no fax received.
Wether its printing any thing? if is printing no need to clean print heads.
check telephone line, if its working, connect the telephone line in line in jack..dial the number check unit it ringing, check out going fax, is it dialing?..if yes check send/receive setting
No incoming/out going replace LIU card..
Sep 09, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
I can't recieve fax
The MP500 is not a fax machine. If you want to send and receive faxes using the printer, you need to have a dial-up modem in your computer with a telephone line connected. The computer then needs some kind of fax application like Microsoft Fax, which does the actual sending and receiving. The printer is just used as a scanner when you send, and to print received faxes.
If you have all this connected already and you can't receive, check your incoming telephone line and fax software settings to be sure the line is answering correctly.
Mar 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Cannot Send or Receive Faxes
here you might find an answer:
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Lexmark X9350 All-In-One InkJet Printer Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
