Question about Sony VAIO GRX700 PC Notebook
DVD-+RW shows as DVD-RW when seen in device manager
I just wonder where to find the right firmware/ driver for this optic drive ( Toshiba SD- R6012) in my VAIO PCG-GRS55B...
  • mothana Apr 28, 2008
    my dvd can not read neither dvd nor cd
    my dvd rom sd-r6012 can not read neither dvd nor cd that wrote with my desk top dvd rom.
    Novelist:
    Scholar:
  • 117 Answers
That's fairly normal. Assuming that's in the model name, then that's just what device manufacturer has put in the ROM in the device and doesn't usually reflect its capabilities. As long as it works on both + and - (if that's what you need), that's fine. If you have a program such as Nero installed, you can look at the actual device capabilities as reported by the hardware itself.
Posted on Jan 21, 2008
Hello.I am having problems with my Lg optical unit on my laptop.The model is HL-DT-ST DVDRAM GSA-T40N ATA Device.I had try to update the firmware but now it doesen't work correctly.Please if you can...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question or exclamation mark ? ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
http://www.opendrivers.com/companydriver/2165/optiarc-free-driver-download.html
you will need to select your operating system
also
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Jun 11, 2011 | LG GSA 4163B DVD±RW Dual Layer Burner
Whenever i put some CD/DVD, it doesn't read at all and I receive this message "Please insert a CD in CD Rom" and there is yellow icon on the device as its drivers are not installed but when i...
Go into Device Manager and remove the optical drive from the list. Restart the computer. It should detect "New Hardware", identify it and install the correct driver.
What's going on: apparently there was a glitch or bug in the Windows 7 upgrade. The DVD drive is misidentified in the Registry as a CD-ROM drive, but it kept the old driver. Of course, Windows 7 thinks a DVD driver is incorrect, so it puts a yellow warning flag on it in Device Manager. It also refuses to acknowledge any disc in there except a CD (stupid computer!). So we need to get the incorrect info out of the registry before Windows will run the optical drive properly.
If Windows 7 gets stubborn about it, turn off the computer, look for the optical drive retaining screw, and take it out and physically remove the optical drive. Now, you should be able to remove the optical drive from the Registry. Restart the computer, double check that the optical drive is gone from Device Manager, then shut it down again. Put the optical drive back in the computer and turn it on. This time it should get everything right.
Jan 02, 2011 | Toshiba Satellite X205-S9810 Notebook
I have loaded windows xp on my compaq presario 2100 notebook pc. the toshiba SD-R2312 CD-RW/DVD ROM is not getting detected due to driver not being there. kindly send drivers file by mail.
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 05, 2010 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
My cd/dvd-rom is not working or even showing up under device mgr on my pavilion ze2000 please help
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If it fails, there is a manual method to edit the registry. Let me know so that I can follow up further.
Apr 03, 2010 | Toshiba SD R6012 (SDR6012-TA) DVD-RW...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
I need driver Toshiba DVD sd r2102
DVD & CD R/RW use generic windows drivers for the most part. Remove the drive from the list in device manager. Windows will then install the drivers again when you reboot.
Mar 23, 2009 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Toshiba DVD-ROM SD 6012
Im sorry to tell you this my friend.. it seems I catch you a bad time but I suggest that you need to replace it with a new drive since CD/DVD writers has its life span limit.. Be careful in doing burn CD's especially if its in long hours since it tend to damage the lens of your drive because of too much heat that was prolonged in a long run.. If your'e using it as DVD ROM at the same time, I suggest that you must have another drive to minimize damage to your drives..
Feb 05, 2008 | Toshiba SD R6012 (SDR6012-TA) DVD-RW...
Toshiba DVD ROM SD R6012 can not burn DVD in my Satellite A25-S307
might be a cd rw /dvd rom player only not burner ? u can buy extrenal dvd rw 79 bucks at any store
Jan 23, 2008 | Toshiba Satellite A25-S307 Notebook
Driver won't work
Are you saying the bios detects the drive, but when you go to My Computer you cant see the drive listed? If so, Right click on My computer and in the menu select 'manage', In the Computer management window select removable media and activate the drive. It will then show in My computer, and be able to read/write cd's/dvd/s. If this does NOT work, then update the firmware for the drive. A lot of times when you buy a new drive, the firmware on it is out of date and the manufacturer has a new firmware out for it to fix computability issues with the collage of hardware thats out there.
Sep 24, 2007 | Toshiba SD-R6372 (SDR6372S) DVD±RW...
Dvd-rom trouble
Hi, first of all, I'd check if you have the problem with CD/DVDs burned (written on a CD/DVD writer) or you have it also with original CD/DVDs, which would be weird. Depending on your finding to the above point I'd do one thing or another, but to me does not look like a driver problem. I'd check with Toshiba support if there's a new firmware for your drive, this does improve the media the device can read and correct problems like the one you mention. To know the fimware version you're using, open device manager and go find your drive, right click on it and choose details tab. Normally the firmware revision is the number at the end of the instance. Good luck mate !
Dec 29, 2006 | Toshiba (SD-M1212-S) DVD Drive
Sony VAIO GRX700 PC Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
