Question about Brother MFC-620CN All-In-One InkJet Printer
Unable to clean
Hi, I have seen this message on a few other models and seems to ref the waste ink tank or absorber sponge, does anybody have a diagram of how to dismantle this model to replace the sponge?
  • Anonymous Feb 11, 2008
    I had replaced a new ink toner yet the message appears "UNABLE TO CLEAN" refer to user guide foor troubleshoot
  • tdunams Oct 05, 2008
    I have the same problem. Is there a solution? If so, how?
Hello, my brother mfc-620cn printer is showing unable to clean see troubleshooting in manual, but I have lost the manual. Can you please advise me on what to do as my daughter has an assignment that she needs to print out for school
Thank-you
Posted on Sep 03, 2008
  • 832 Answers
See here (mfc215c; it is the same procedure)=:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
Posted on Jan 21, 2008
6ya staff
SOURCE:
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I have error message E 8 What do I do?
Hi
Error E8 means waste ink absorber full. To clear this error you'll first need to clean the waste ink absorber. It is located on the right side when you'll open the front cover.
Please turn off the printer and unplug it before performing any operation. After opening the front cover use a paper towel to absorb off the excess ink on waste ink absorber. Wait for 2 minutes before plugging back the printer.
Please get back to me if you have any issues in performing this.
Daniel Scott
Jun 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
MP 610 is leaving black ink streaks the length of the page on back of paper. I have used the printer maintenance to clean the rollers, ink head etc several times and have installed a new black ink...
That sounds like the ink is coming off the waste ink absorbers. Try blotting the excess ink off the bottom of the printer with paper towels. The ink absorbers are small pads at the bottom of the paper feed path. With work, you can pull them pads and rinse them clean and then reinstall them when dry. Unfortunately, this can take almost disassembling the printer. Simply absorbing some of the excess is a temporary step.
I hope this helps.
(there is a counter that indicates when (based on average use) the waste ink absorber is full. The printer will stop working when that number is reached. Unfortunately, I haven't seen a reset for this model that actually works.)
May 17, 2010 | Canon MP610 Photo All-In-One Printer
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
Ink waste Absorber
you are correct about the waste ink tank,did you check the pipe (if any)which use to carry the ink to waste tank,if it is clogged than also the problem will arise.
Mar 31, 2008 | Canon PIXMA iP2000 InkJet Printer
Waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Mar 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Help with absorber
Someone else asked same question on this site and got answer:
http://www.fixya.com/support/t198707-ink_waste
I also had that message. This seemed to work to clear the message and let you carry on printing.
Also, I may be wrong, but the actual ink absorber is the sponge part by the rollers underneath when it prints. I dont know if it has sorted the actual problem, but I took the sponge part out (I have an MP130 and the sponge part lifts straight out if you carefully put your finger underneath it on the left hand side) and let it soak in water, sqeezing it to get the ink out (It was full of ink so careful not to get it everywhere as it can be a little messy). When it had dried, I carefully put it back in (make sure you put it in the right way around).
Hopefully that now means the ink absorber is again empty AND the error message has gone.
Not sure about the whole cleaning the sponge idea, but I did it and according to the manual that sponge is labelled as the ink absorber so technically I have emptied it?
I haven't seen any posts about actually cleaning the sponge so take that part as you will.
Dec 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Immovable Cartridge & Printing problems
try to remove the front cover of the printer is 2 screews or 3 and a few clips and whit a clean cloth absorb the waste ink from the waste tank, and this is o quik fix that i use.
Oct 18, 2007 | Office Equipment & Supplies
Brother MFC-620CN All-In-One InkJet Printer Logo
1,000 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
