Question about Denon AVR-3806 Receiver
Startup Turns off back to standby mode after about 5 seconds when turning on from standby mode. Tom
  • 67 Answers
Going into protect due to either blown channel or probably a 15v regulator might be down which I have seen many times also. causing unit to go into protect.
Posted on Jan 31, 2008
TomTom GPS battery discharge when off
With the TomTom GPS units, if you use it infrequently, you may often find the unit has a dead battery when you go to use it.
This is because turning the Tom Tom off normally with the power button doesn't actually turn it off fully, but instead puts it in a standby mode.
Even though the screen is off and it appears to be shut down, it's still using some power to maintain configuration settings.
If you know you won't be using it for a long period of time, you can press the reset button on the bottom of the unit (this can be done while it's off), and it should put it in shutdown mode, where the battery will not be drained so rapidly. If you do this, you can confirm it's in the shutdown mode by tapping the on button. This normally will power up the Tom Tom, but in the shutdown mode, it will not do anything. To wake it up from the shutdown mode, press and hold the power button for a few seconds, at which point it should turn on and greet you with the Tom Tom drums. It takes quite a while to boot up from this mode, which is probably why they defaulted to the suspend mode instead of a true "OFF" state.
For some of the newer units, they've omitted the reset button, so the process is a little different. Instead of pressing the reset button, do the following:
with the unit on, press and hold the power button. The shutdown screen should appear, but continue holding down the power button for another 12 seconds after the screen turns off. Timing is a bit touchy, because if you hold it too long, it'll end up just rebooting, and then you'll have to try again.
If you're successful in the shutdown, you can test it by briefly pressing the power button. It shouldn't turn back on with just a short press. If it comes on with the tap on the power button, you'll have to try again.
This whole process is a bit of a hassle, and extends the turn on time greatly, so you'll want to plan ahead when doing this, and just shut off normally if you expect you'll be using it within a couple days. However, the long boot up is preferable to having a completely dead unit when you need it, especially if you're away from a power plug...
on Jun 30, 2010 | GPS
My daewoo model dsj-4710 turns on but goes right to standby need help finding out whats the problem
main power supply which has the standby supply with it--look for those pesky puffed up filter caps.
Dec 16, 2012 | Televison & Video
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Lenovo t400 cannot boot. have "z" light only
Hi vincent,
I see that you have a "z" light indicator on the system when powered ON but you see no video on the screen.
The "z" Indicator means that the system is turned ON and ready to use but is in standby mode.
To disable standby mode on your system simply press the FN button for about 5 seconds on the system make sure that the machine is turned ON, this will make you system go back to normal mode.
For additional info on the issue the system can be put to standby mode by holding down the FN+F4 for a second or two this will enable standby mode on your Thinpad T400 and to disable the standbymode press and hold down FN for 5 seconds.
I hope that this will be of help regarding you concern, have a nice day.
Mar 30, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Maxent MX42VM10 just turns on for a second and goes to standby
You have a two part problem here 1 is a bad capacitor in the unit witch is preventing startup another another would be your decoder board witch is causing those flashes on the screen just before it remits back to standby. My professional advice is simple take it in get a estimate on it if it cost you more then $200 to fix it then you might want to get a repair manual and do it yourself or find a low cost tech that knows this stuff. Otherwise you will need to search for its replacment, let me tell you plasmas are not going to be servicable after july 2011 so get it fixed while you can or find a good home for it.
Nov 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
My modem is off
Modem and coaxial cable abnormally connect, or probably loosing power from internet. ask your local ISP
Jun 24, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Denon AVR-3806 Receiver Logo
287 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
