Question about Harman Kardon AVR 7000
AVR 7000 REMOTE IS BROKEN.HOW CAN I CHANGE THE SETTINGS OR BRING UP OSD W/O IT?WHER CAN I GET A REPACEMENT?>
  • chris ZAMBROTTA
    chris ZAMBROTTA Jan 21, 2008
    thank you ,i did call them nd the remote is discontinued.there are other companies selling the remotes at a ridicuos 200 dollars.i have the small remote the works also an older remote from a avr5 the controls everything ,but it doesn' t control the osd function which is need ed to adjust setting that u cant adjust w/o bringing up the osd.Is the a combination of button i can toggle on the face of the unit to bring up the osd?
    also is there a aftermarket universal remote that will controll the osd function,if so please give info.
  • 3 Answers
Harman Kardon has a great website on Ebay and they sell just about everything you can think of, new and remanufactured there. If you don't see this remote advertised just click on something they are selling and call them directly. I bet they have it in stock and will ship asap.
Posted on Jan 21, 2008
Can't access osd on screen display from remote control
Have you checked to make sure your TV is on the correct input?
It should be on the input the Receiver is connected to in order for the OSD to appear .
Sep 30, 2014 | Harman Kardon AVR 135 Receiver
The remote control do not work
Change the batteries. Make sure it's on the mode that operates the receiver. Check the IR output using your mobile phones cam.
Sep 15, 2014 | Harman Kardon AVR 7000
I hope this mail finds you well.i am not getting sound from the surround and center speakers.when i test my speakers i only get sound from the front speakers.
hi,
check ur speaker connection first or may be ur receivers speaker setup have some problem. except frond speaker all the others will be off mode. change the speaker setting.
press osd button on the remote to bring audio setup. select ur speakers large or Small or large according to ur speakers. then test again.
if u connected an analog audio input then press surr (surround mode button) to select the mod you want)
ok
Dec 18, 2010 | Harman Kardon AVR 7000
Hello, I have an denon avr-3801 and have the same problem that my set up will not pop up on the display screen. one expert on here said it can be disabled on the remote, and to enable it. How do you do...
The setting on Page 26 says it only turns OSD off for messages other than the Menu Screens. If you could turn the menus off how would you ever turn them back on?
If you are using only component video, see page 10, 3rd bullet.
"The AVR-3801’s on-screen display signals are not output from the color difference (component) video output jacks (MONITOR OUT)."
It needs an s-video or composite path for the OSD.
Jun 08, 2010 | Denon AVR-3801 Receiver
Install problems at AVR 142
ensure that you have the reciver connected to a display monitor e.g t.v. set, there you'l be able to make all the necessary ammendments.use the video out or use the HDMI out to connect to your t.v.
which speakers are using for the avr 142?
Dec 24, 2009 | Harman Kardon AVR 140 Receiver
Is it possible to have OSD (on the TV) with a standard AV receiver?
Yes.. Newer (or some) AVR's you can, by selecting OSD "on" in the start up menu. This allows you to view your devices individual settings. Older AVR's by selecting the same option as with newer AVR's OSD option "on" you would also have to pass at leat one seperate s-video, composit, or component out conection from the unit to your AVR to get the OSD. If the signal from the component conection is anything but Standard (SD) or 480i the AVR would not be able to overlay your program with the OSD, thus OSD will appear without the program.
Dec 31, 2008 | Televison & Video
Harman Kardon AVR 7000 loosing memory
This is what's in the AVR7000 service manual:
Subject: Backup Memory on AVR/DPR/HK series receivers.
In the event of the complaint: “the receiver is losing its memory (any programmed system settings)
when the unit is turned off, or after the unit is unplugged (briefly*)”:
Check and replace:
Model: AVR7000
Designator: C730
Description: 0.047 Farad 5.5v capacitor
Part number: # P10790-ND or # J3432147324X
I'm having the same problem and this is how far i got so far. I don't kwow how to get and replace this part.
Oct 25, 2008 | Harman Kardon AVR 7000
OSD not working (black screen)
Your 635 will not display the OSD screen through component. You must use either s-video or rca. It won't upconvert the screen menu this route.
I had one up until a week ago. There are two outputs on the back specifically for the OSD screen. I used a separate old 13" TV with s-video to do my setups. Hope this helps.
Sep 04, 2008 | Harman Kardon AVR 635 Receiver
Marantz sr-7200 no OSD
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Jul 24, 2008 | Marantz SR-7200 Receiver
720p output doesn't work
The problem might be that the set can not handle the change in signal. Try setting the AVR-247 to 720P first then turning on the set. Or manually set the TV to receive 720P then change the AVR. TI believe that you have a connectivity issue where the two units are not speaking the same language at the same time. Update this with your results and please post the TV make and model.
Thanks,
Dan
Apr 01, 2008 | Harman Kardon AVR 240 Receiver
Harman Kardon AVR 7000 Logo
238 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
