Question about Harman Kardon AVR 7000
WTF is wrong with my harman kardod AVR7000?
I have a avr 7000 whe i try to play any thing any way other then 6 channel0in ,i get only the front left channel at low volume,stereo plays both front ,but the vmax mode just plays left front.i tried various inputs same result also test tone in any other mode exect stereo just left front.I call h/k they told me its the processor.Ok i kind of figurede that.dsp.have any body had th is problem?what part needed top be replaced?
and how muchdid it cost?and where can i order the parts from and how much did they cost?
I might try to fix this 1 myselrfif its just a diode or resister or capacitor.If a ic ill bring it to the shop.Also 4 future info does any1 know a good detailed repair forum?
  • brokenfun Mar 31, 2008
    Same problem. "Scratchy" sounds when using Surround.   3 and 2 channel works.  Sometimes, after power-up, everything is fine for a few hours...  Took it in for repair, quoted $560 for 42 caps. This estimate seemed high, what do you think?  I declined and bought a new Amp.  I would like to try to replace the caps myself, bad idea?  Some soldering experience here. Or, do I leave it alone, and sell the remotes on eBay?  I don't need them in the shop/basement... It still works great as a 2 channel amp, but, will  it eventually die as a result of the cap failures?
  • 32 Answers
Hey, I just bought a used avr7000 from auction and it has similar problems that you and others have posted on the net. From the receiver mine has no audio and at times minutes/hours apart sound comes out for a few seconds and then cuts out again. i have yet to try the inputs, you can download the service manual from www.eserviceinfo.com i am of the understanding that the problem is on the DSP board(it has the digital/optical inputs), primarily the 10uf capacitors(about 10) need replacement. Im am yet to try anything, the board looks delicate and would required proper soldering and desoldering tools. from australia
Posted on Feb 19, 2008
L/ front audio out not working fully. pre amp channell working & headphone L/front working. Can you advise
The left channel output in the amplifier stage is going out - could be a cold solder connection due to overheating. Check the left channel output of the power transistors solder trace - you can compare them to the right channel stage because they're almost identical circuits.
Nov 04, 2010 | Harman Kardon AVR 7000
I NEED THIS PART FOR MY AVR7000 STERO
Hi, Look on partstore.com or shopJimmy.com to find parts. Thanks.
Sep 21, 2009 | Harman Kardon AVR 7000
The receiver keeps shutting of automaticly you push the on button and you can hear the sound but only for seconds and then it turns off
chayni_richa hello I have the same problem with the Harman Kardon AVR 7000 is off to the moment that I turn it on, you've been able to solve it? please tell me things jurbib@aol.es thanks
Apr 18, 2009 | Harman Kardon AVR 7000
Harman kardon avr 7200.1 no volume left front speater
could be a few different things. if you have tried another speaker that you know is in working condition then it might be a connection on the amp itself or the terminal could be bad. does it look coroded or is there anything obstructing its connectivity?
Feb 18, 2009 | Harman Kardon AVR 7200 Receiver
Right Front and rear speaker do not work proberly.
I ran into the same issue with an AVR 7000 after it had been shipped to me. I took the cover of and found that the left and right amplifiers have a separate power plug into them. when I plugged to "bad" side back in everything worked great.
Dec 30, 2008 | Harman Kardon AVR 7000
Harman Kardon AVR 7000 loosing memory
This is what's in the AVR7000 service manual:
Subject: Backup Memory on AVR/DPR/HK series receivers.
In the event of the complaint: “the receiver is losing its memory (any programmed system settings)
when the unit is turned off, or after the unit is unplugged (briefly*)”:
Check and replace:
Model: AVR7000
Designator: C730
Description: 0.047 Farad 5.5v capacitor
Part number: # P10790-ND or # J3432147324X
I'm having the same problem and this is how far i got so far. I don't kwow how to get and replace this part.
Oct 25, 2008 | Harman Kardon AVR 7000
AVR 7000 audio/video receiver
Harman kardon amplifire are known for that.specially AVR 7000
but sometimes this comes from poor wiring and using a wire that will not conduct better sound. Remember your wiring is very important.you may think your wiring is currect, better to double check. even if your connection is ok and the wire you are using are not better to produce quality sound you will not get sound from every speaker.
good luck
Feb 28, 2008 | Harman Kardon AVR 7000
Avr 7000
WAT BRAND SPEAKER AND RECEIVER?POSSIBLE OHM ISSUE?WAT IS THE IMPEDENCE ON THE AMP AND CENTER SPEAKER,.HAVE YOU TRIED RUNNING A 6?8 CHANNEL CONFIG?FOR EX.USING YOUR SOUND CARD THROUGH THE PREAMP AS A DSP. WHE PLAYED IN SHOP HE USESD CD? U USING SAME CONNECTION FROM THE SAME INPUY? OR IF LISTEN ING TO RADIO. SOMETIMES THE SINGNSAL IS NOT IN A DIGITAL FORMAT SO THE PPR LOGII C CANT PRODUCE IT.IT WOULD BE PLAYED ANALOGICLY.MEAN NO CENTER.
Dec 26, 2007 | Harman Kardon AVR 7000
Harman Kardon AVR 7000 Logo
633 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
