CHANNEL INDICATOR WON'T CLEAR
The problem,although not a great one is on my Grandads Bush 2876ntx TV. The blue channel indicator is always on(top LHS) and the only way I can find to clear it is to switch to teletext on the remote then back to tv by pressing the button again. It then remains off until say the volume is adjusted. The vol display appears then when it goes off after a few seconds, the channel indicator comes back and stays on as before. As I said it's not a massive problem, but as he watches sport a lot, the scores/points are often behind the channel indicator. Hope you can help. Gareth UK
  • gareth1 Feb 10, 2008
    Thanks for advice. Sorry I took so long to respond. Was a bit sceptical that it would be such an easy fix, but eventually tracked down his instruction manual which showed me how to get into setup overview. Changed the OSD from on to off. It now shows up briefly when a channel is changed and goes off. Thanks again. Gareth
  • gareth1 Feb 11, 2008
    Sorry man! Haven't used this site before. Didn't even realise I'd given you a poor rating until you replied. I've changed them I think to "Fixya"?? My comments and rating now don't contradict each other.
    President:
  • 3,130 Answers
This is a setting in the menu set-up somewhere or simply press the display button on the remote control unit.
Posted on Jan 22, 2008
  • Larry  Dillon
    Larry Dillon Feb 10, 2008
    Thanks for the poor rating man! Thanks for trying? If I had not told you what to do, you would still be looking at the numbers.
  • Larry  Dillon
    Larry Dillon Feb 11, 2008
    Thank you!
How do you make Bush TV Passive 3D
Only if it is a 3D television.
Bush 3D TV - Passive 3D TV Bush 3D TVs are exclusively available through Argos. Make sure you check if the Bush 3D TV is passive or active, it isn't always clear on the site. To ensure that everybody can enjoy 3D TV our family packs contain two, four and six pairs of designer 3D glasses by Oskav.
Oskav Designer 3D glasses are compatible with all Bush passive 3D TV
How do you make Bush TV Passive 3D Google Search
Feb 25, 2018 | Bush Televison & Video
How do I get my Bush tv to start in HDMI mode not tv
you cant,the tv will always come on the tv channel. you can turn the item off that is plugged into the hdmi port then back on and it will take over the tv channel and switch to hdmi. so on a night turn off the item plugged into the hdmi port and on a morning after your tv has turned on then turn on the hdmi item and the tv will switch over itself
May 30, 2015 | Bush Televison & Video
My Bush 24" TV is only showing a white screen !
Check the video output voltage to CRT board. It might be absend.
Apr 26, 2012 | Bush Televison & Video
We have a bush set top box with no instruction book. one channell Win (9)is indicating ''no reception'' We were told by a local TV repairer to re tune our tv. How?
Hi
You should not have to re-tune your tv as the set top box will be plugged in via a scart lead so its the set top box that needs to be retuned.
Go to the menu of the set box and select new installation under features or set up.
Hope this helps
Apr 09, 2010 | Televison & Video
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
How do i retune my bush 1433
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Sep 29, 2009 | Bush 1433GRN2 14" TV
I have a Bush DVB-T set top box with no remote how do I program i
I NEED THE DRAWING OF THE CIRCUIT BOARD OF BUSH DVB DFTA 11/A
May 26, 2009 | Televison & Video
BUSH LCD 17TV004 picture goes off!!!
if yo know how to solder , re solder your tv, second adjust the IF transformer by using the plastic or wood stick. IF transformer is looks like a cube made of metal with an adjustment screw at the top. try to adjust it and observe what happen.
Oct 16, 2008 | Bush 5693D 24" TV
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
