The dishwasher fills with water as normal and you hear the pump working but if you open the machine door, you can tell that the dishes are not being sprayed with any force. Mainly the steam from the hot water does any of the cleaning
I wonder if CLR can help clear the blockage, my area has very hard water.
Any assistance is much appreciated.
Thanks
CLR can be great if it is hard water blockage. If it is food blockage or a lot of hardwater you will have to dissassemble part of the sump pit and manually clean the blockage. Please rate this post.
Testimonial: "I filled the dishwasher with water added 1.5 cups of CLR and left it to soak for 10 hrs. I ran two complete cycles to flush the CLR. It's like new.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAINto work when it is commanded .If this does not happen then the voltage at these pointsmust be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure.If so the pump must be checked for clogging.
Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
You said you had water under the dishwasher,did you remove the lower panel below the door and check for water in the base frame as well. Bosch dishwashers have system in the base frame that detects water in base and cuts power off to every component except drain pump till it no longer sees the water in the base.
Is this a dishwasher or a washing machine that you have a problem with.
The drum is usually in a washing machine. The motor you hear running is the drain motor. So this is a normal operation of front loading washing machines. When the drum stops spinning, the drain pump takes away the remaining water and then a timer lock comes into play to make sure the clothes are settled dowm before you can open the door.
So I do not see there is any problem. Please accept the solution if ok else post a comment to confirm the exact problem with your appliance.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ?And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump obviously it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro.
you have a bad fill valve. unplug the unit from the wall or turn breaker off and tell me if the water still comes in if the answer is yes you have a bad fill valve.
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures. 2.Make sure probes are clean. 3.No water pressure — main water supply valves may not be working. 4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. 5. Delime machine.
The unit has a double valve system, the waterproof, it could be that one of the valves is not opening fully. They can break down over time. This would mean you need a new one. This should fix the problem.
Open the door once the wash has started and check the water level. It could be that it is siphoning out half way through the wash. Make sure your drain hose is secured up properly.
If when you open the wash and there is not enough water, it is most likely the waterproof, as I stated before.
cheers.
It is very possible that something could be obstructing the main pump. But, first. Does your dishwasher fill with enough water? When full, the water level should fill to just below the heating element. You can check this by waiting for the fill cycle to stop and the normal wash cycle to begin. Open the door and check the water level. If your dishwasher isn't getting enough water, you could have a bad fill valve, or the inlet water line could be kinked. If this isn't the case, then suspect that you might have a clogged pump. Food particles such as popcorn kernels, orange or lemon seeds, small chicken bones and glass are notorious for getting into the pump screen area and obstructing the water flow (some of the other items I have found are labels off jars, bottle top seals, twist ties, rib bones, hair scrunchies, and yes - even band-aids!). Even though some dishwasher manufacturers advertise some amazing capabilities of their dishwashers, you still need to scrape your dishes of all food particles as much as possible. This does not mean you have to pre-wash prior to loading them. Anything that doesn't get dissolved by the wash cycle and detergent will end up sitting in the pump well. If the pump isn't able to pump enough water, your dishwasher will fill normally, but the spray arms will not turn, detergent does not dissolve and your dishes will not come clean. To get to the pump, you need to remove the lower spray arm and the coarse screen (located directly under the lower spray arm). The pump well should be located under the coarse screen. Look for anything that may restricting the water flow. I hope this helps and it's easy fix for you.
