Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG Dishwasher LD12AW2
Our dishwasher will not allow water to enter. The system seems to start normally with no error showing. The time clock and all program buttons seem to be operating normal. I replaced the water solenoid valve and checked the door switch.
Can anyone please provide a solution
  • 1 more comment
  • desydog Feb 29, 2008
    turn machine on and it powers up when start is pressed. the pump doesnt seem to kick in. no fault code displayed. It seems as though it is paused. Im not game to delve too far as I dont have an instruction manual.
  • mistermenor Apr 27, 2008
    My dishwasher LD12 aw2 also will not pump water in ,starts then shows IE message.Tap is on and hoses are not blocked.Is the pump gone or something else ????
  • desydog Jun 16, 2008
    I had my machine checked and it needed a new computer. Approximately $330 repair bill but if machine not too old, I think its worth it.
My LG model LDF7811ST dishwasher fills with water at the bottom of the dishwasher but water does not come out of the spray arms to clean the dishes. The spray arms are not clogged. I don't get any error codes.
Posted on Jun 16, 2008
    Sergeant:
    Champion:
  • 262 Answers
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Posted on Jan 23, 2008
Dishwasher is powered on but and making normal start up noise but no water is entering the dishwasher and not beginning the wash cycle
My Dishwasher is a Blomberg DWT 25200 SSWS. It had the same problem. It powers up but no water enters in it and the clock didn't advance. This is what I did to fix it.
You can display the error code by powering off the dishwasher then pressing the 'Program' and 'Half Load' buttons at the same time then power on the dishwasher. This will show an error on the screen. My error was E:1.
The problem was a disconnected blue hose at the bottom of it.
This is the overflow detector.
This little board has a 12 Volt relay that activates the main water valve which is a 120 VAC valve. There was nothing wrong with it.
This plate is at the bottom of the dishwasher to hold the water that spills.
May 07, 2015 | Blomberg Dishwashers
What can cause and lg dishwasher to not fill water and stop and show le code
Please try the plain VINEGAR in the bottom of your dishwasher. It cleans out the pipes. When you start the machine it automatically starts to drain whatever water has been left from previous cycle. When this cannot happen, due to blocked outlet pipe, it will not precede with the wash cycle. Adding the vinegar, leaving it a few hours, or overnight (hey, I left it for a week one of those times!), it is enough to liquify any heavy fats in that pipe...enough to start the cycle and the normal draining gets reinstated.Hope this helps you, it is such a pain to go & choose another dishwasher to fit into the space allowed & that has all the functions you need. This 'fix' cures all my dishwasher blues! Havagreatday!
Sep 21, 2014 | LG LDF6810ST Stainless Steel Built-in...
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
Stopped - no error message, power, drainage lines all good Andy
No Power on when the power button pressed.
Check out the web site
http://spares.bigwarehouse.com.au/file.php?document_id=5831
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
2H accures in digital read out. NO Cycles start, just a humming
Do you own an LG LDF6810ST dishwasher? If not, please reply with the manufacturer name, model and serial number.
Are you saying that the display that normally shows the time is displaying an code of 2H? On an LG, that means 2 Hours, (120 minutes) and is not an error code.
On an LG with a symptom like this, I would arrage to replace the main processor card (PCB). You would be getting an error message if the motor (wash or drain) had failed.
Mar 30, 2009 | LG LDF6810ST Stainless Steel Built-in...
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LD12AW2 Dishwasher overflowing
On the LG LD-12AW2 model, there is a float assembly just behind the wall where the water inlet port is located inside the unit.
When that float (or the micro-switch inside it) fails, water will continue to flow in without stopping . That causes the overflowing.
Post back here if you are looking for more specific guidance.
Good Luck!
Dec 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Too much water where is fill switch
the fill switch is actually a pressure swith located at the bottom front of the d/w.
take care.
Jul 20, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD12AW2 leaking
The fill switch may be contaminated with soap or debris that makes it heavier and makes it float lower in the water which means more water is required to trip it. Try moving it manually and see if it is hard to move at the top of its travel.
Oct 28, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
822 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
