Question about Canon L220 Plain Paper Laser Fax
Manual sending to more than one client
Hello I did not understand how to proceed to send faxes to more than one client manuallythks in advance
    Sergeant:
  • 287 Answers
The MANUAL should assist
Posted on Jul 16, 2008
When i send a fax my client gets a black copy
Your SCANNER UNIT has failed, very expensive to fix.
Apr 02, 2010 | Canon FAXPHONE B640 Plain Paper Bubblejet
I use my fax daily to receive faxes. I have one client who faxes me and it takes hours for it to print and either errors or prints a blank page. Right now I am waiting for a fax to print out that was...
Your client probably has a phone line problem causing errors.
The first test is to send a FAX to that person. Does it proceed normally?
They may share the line with a telephone or other device. IF they have DSL they MAY have forgotten to put a DSL filter in line for the FAX.
If they send the FAX from a computer there may be MANY other reasons the computer hangs up.
Mar 15, 2010 | HP 1040 Plain Paper Inkjet Fax
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
Oct 03, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Problems sending to a particular number
Try sending your fax to a lower baude rate to 14,000 bps, I had this problem before and I solved it by sending to a lower sending speed bacause the line was very noisey.
Mar 16, 2009 | Canon LaserCLASS Fax 710 Printer
I need to print instructions on how to use a brother fax -645 machine. how to set and send faxes
An on line manual probably does not exist. Put paper in feeder face down, dial number, press send.
Sep 11, 2008 | Sharp UX 108 Roll paper Thermal Fax
Error 350
Error 350 means...
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try this solution...
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved. (To turn off the ECM, simply press the setup button on the pritner, use the right arrow and select advance fax setup on the options. Press ok under advance fax setup. Use the right arrow and select Error Correction Mode. Press ok and select Off.)
*Try sending at a lower transmission speed. (To lower the transmission speed. Press the setup button, go to advance fax setup. under advance fax setup, look for Fax speed. change the fax speed to slow)
After you have done the T/S, try sending a fax again.
Hope this would resolved your issue.
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp 5610 won't receive fax from lexmark fax
Are you able to receive faxes from others from the same location, if not just ask her to consult her service provider and ask to get the no checked of yours why is it that you she is not able to send fax to you only as your fax machine is capable of sending and receiving fax from others it should be dsome issue with her service provider.
If it was your All-In-One printer thrn you should not have received faxes from any one, not a specific number.
Good Luck
Aug 19, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam, error message, fax send comes out not ledgable.
Code 43 is a line error according to Panasonic.
I had this issue trying to send to a client yet I could send faxes to other #'s. So in my case it was a dead fax on the other end of the line.
Jun 13, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Canon L220 Plain Paper Laser Fax Logo
57 people viewed this question
old marine
old marine
