Question about Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB / ATA-133 / OEM / RoHS Compliant / with CA Des (890552605880) Hard Drive
Maxtor hard drive needs a chip replacing
Hi i have 2 Maxtor diamond max 10 16mb cache and i plugged them into a sata power splitter as my psu only had 1 it has destroyed a chip on the green plate underneath close to the connector for the power. Can this be replaced? thanks kind regards Paul.
  • vmaxzile Jan 24, 2008
    thanks will try that.
  • ashmanmedia Jan 31, 2008
    I have a 500gb maxtor that I just recently spent days on end collecting all my data and organizing... it was externally powered and slipped and a white circular piece labeled "1R5" came unsodered.
    No power... Maxtor/Seagate tells me the do not repair physically damaged drives. the plater is fine wth.
    what is this white thing called can I buy a new one radioshack and attempt a soder.
    Problem Solver:
  • 23 Answers
Unless you can find the matching chip and are good at soldering these small parts, it can be replaced.
Typically, I would suggest looking for busted harddisks (of the same model) and if their board was still good, just do a direct swap. I did this for a Fireball model HDisk.
Or if their board is busted, you can get the chip from them and, like I said earlier regarding soldering, solder it onto your Hard disks. This is considering that the only part busted was this chip.
Posted on Jan 23, 2008
How do I install my320 GB Diamond Max 21 internal Harddrive setup as a external drive with USB 2.0 to computer, The S/N is 9QF09BA4, STM3320620A and firmware3.AAE Date Code is 07143. I have two that I...
I am unsure if you are trying to take a currently external drive and mount it internally, or if you are trying to make an internal drive into an external. Please clarify.
Feb 13, 2011 | Maxtor 7L320S0 320GB 7200RPM 16MB SATA/150...
Trying to install as slave. check disc checks it then computer stops???
since you have been connecting another hard drive and plugging the leads in/out
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection
i would also suggest you buy another PSU power supply unit preferably a heavy duty one with plenty of wattage when you add more devices ram,hard drives,cd/dvd recorders it drains more power from the power supply unit placing more strain on your computers PSU
and are not faulty or just replace them there probably old and faulty
Nov 30, 2010 | Maxtor DiamondMax 16 80 GB Hard Drive
I try to install winxp but it always fail and restart by itself.. my setup is: -pentium 4 630 3GHz -ocz platinum rev 2 ddr400 512MB x2 -maxtor diamond max 80GB SATA
One bad lead will cause your computer to continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Sep 19, 2010 | Asrock 775VM800 Motherboard
Jumper settings
25870e5.jpgCheck this diagram. it shows all configuration in detail..
good luck!!
Jan 02, 2010 | Maxtor Hard Drive
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Maxtor hard drive xbox 360
The maxtor hard drives will work with an Xbox360 but in only one case, your xbox hard drive is linked to work only with your console and if you swapped hard drives the xbox wouldn't read it so to answer this you need to reset your Xbox 360 copy protection serial number i.e. Flashing your Xbox or Chipping it, once your Xbox is Flashed or Chipped you can use a maxtor hard drive through the SATA cable port in your Xbox
Oct 13, 2008 | Maxtor Hard Drive
Can i use this maxtoe diamond max 21 500 gb drive for a c drive i am removing a 80 gig that is defective
If you mean remove your old 80 gb drive and replacing with the Maxtor 500 gb drive you should be able to. The Maxtor 21 series is equiped with SATA. Just make sure that your computer can run SATA. If not, I believe that there are adapters out there.
Oct 01, 2008 | Computers & Internet
Video and photo files
Dear Friend,
Point your browser to
http://stason.org/TULARC/pc/hard-drives-hdd/maxtor/87000D8-DIAMOND-MAX-7000MB-3-5-SL-ATA3.html
or
for more drives to
Alternatively
JumpersMAXTOR DIAMOND MAX INSTALLATION SHEET
Jumper Setting
+---+---+---+---+---+ |J50|J48|J46|J44|J42| +-------------------------------------+---+---+---+---+---+ | Master/Slave | | | | | | | Only Drive in single drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Master in a dual drive system* | J | | | | | +-------------------------------------+---+---+---+---+---+ | Slave in a dual drive system | O | | | | | +-------------------------------------+---+---+---+---+---+ | Cable Select | | | | | | | Disabled* | | O | | | | +-------------------------------------+---+---+---+---+---+ | Enabled | | J | | | | +-------------------------------------+---+---+---+---+---+ J=Jumpered O=Open *=Default
Feb 05, 2008 | Computers & Internet
Jumper settings for a Maxtor hard drive, Model 87000D8
This looks like documentation from the time but it is not from a manufacturer's site.
near bottom of page.
Jan 01, 2008 | Maxtor Hard Drive
Maxtor 4R120L and Maxtor 4R160L
It is possible to replace/transplant the circuit board. But I am not sure of the motor and the platters. I would suggest you not to play around with the platters. If you wish to replace the circuit board (I guess it is also called the logic card) get a hdd of the same make and size and replace it with this one.
Nov 09, 2007 | Maxtor Hard Drive
Open Questions:
How to Save Data Backups for 100 Years - Data Backup and Online STORAGE Get all you important data saved safely and securely on the highly advanced online cloud backup solution of Dataalign. This facility of providing large space for online cloud backup is different from its counterparts as it makes optimal use of advanced technology to device features that helps the user to make maximum use of the available space by setting the number of versions and days you wish to keep a file after which it is automatically deleted. Also, the feature of version history helps in viewing the history of each stored file and thus, also let's undo decision mistakes if made in the past. The server cloud backup solution of Dataalign is an amazing way of backing up all your files, folders and data whether related to your business or personal. Many more amazing features of Dataalign makes it super secure and easy to use by anyone. There are different categories of backup plans in Dataalign for various uses. You can choose the plan according to your needs from home free backup, personal standard backup, social backup, personal pro backup, family all in backup and home pro all in backup. The Unified cloud backup feature of Dataalign cloud backup helps in securing data located on various platforms and in different devices at a single place. Everything on your computers, tablets, and smartphones, external drives, servers, network devices and even cloud services like dropbox automatically get imported and saved on Dataalign. The cheap online data backup of Dataalign provides easy access and retrieval of data from any place using any device. Free cloud data backup of Dataalign helps in protecting all your data like documents, photos, music, videos, contacts, messages, calendar, call logs etc. In case of situations when your device gets damaged or you want to upgrade your device, you won't have to worry about transfer of data. You can import all your data by simply installing the Dataalign cloud backup app. With Dataalign keeping all your data safe, you can search and discover documents, presentations and spreadsheets from any device. You can even discover OCR content from scanned PDFs and images. For more information and cheap online cloud backup contact Dataalign at toll-free helpline number +844387-9959.
Sep 21, 2018 | Super Computers & Internet
See all Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB / Questions
Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB / ATA-133 / OEM / RoHS Compliant / with CA Des (890552605880) Hard Drive Logo
132 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
