Question about RCA 20F420T 20" TV
RCA 20F420T FPA lock
I accidentally turned on the FPA lock on my roommates TV. I have researched it and I have found no solutions. The keys on the front of the TV do not work and I can not get the universal remote to work either. Should I buy the original remote or is there something else I could do? I prefer not to have to spend any money. But like I said its not mine, and I really do not want to have to buy them a new TV. PLEASE HELP ME!!
Thank You!!!
  • 10 more comments
  • Anonymous Feb 22, 2008
    MY FPA WAS ALSO LOCK,YOU MUST HAVE THE REMOTE,JUST PRESS 1111 OR 0000 THEN OK,IT SHOULD COME UNLOCK.HOPE IT HELPS!!
    ZEKE
  • Anonymous May 25, 2008
    i accidentally lock my tv on fpa lock on have can i unlock it please
  • Anonymous Jul 08, 2008
    i turned on FPA lock and i cant do anything help please
  • Anonymous Aug 14, 2008
    fpa is on the tv screen
    FPA IS ON TV SCREEN
  • sierra08 Sep 07, 2008
    i accidentaly turned the FPA lock on my tv and i cant figure out how to unlock it help me !!!!!
  • georgianjmw Oct 13, 2008
    I am having the same problem, i turned my FPA lock on and then shut it off thinking it would re set now it wont turn back on, i dont have a remote. what can i do
  • trublu187 Dec 29, 2008
    same problem
  • sandy10161 Jan 04, 2009
    I am trying to hook up a DVD player to my TV and the FPA lock is coming up on the screen and you cant use any of the TV buttons on the TV and I cant find the original remote that goes with the TV.
  • jesusalfre Mar 13, 2009
    My remote is not working and the front button don't let me star the TV. What can I do?
  • dsoet2002 May 11, 2010
    How do I unlock my TV, from FPA lock
  • Larry  Dillon
    Larry Dillon May 11, 2010
    When you say FPA Please explain. Are you refuring to the parental lock or the V-chip access ?
    President:
  • 3,130 Answers
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Posted on Jan 24, 2008
  • njg55 Jan 14, 2011
    It doesn't seem to work with a universal remote and I lost the original long ago. Cannot use the TV now as I need to do a scan with a converter to get stations. All it's good for is DVD's :-(
  • junior_69 Apr 09, 2011
    simple universal remote
If you have a universal rca remote or any rca remote this is what i did. go to the menu button, press preference button or scroll down to the preference button and go down to fpa lock to turn off.
Posted on Feb 27, 2009
    New Friend:
If you lock yourself out of your RCA all you have to do is buy a RCA universal remote. At any walmart for about $10.00. The remote automatically connected to my TV got into menu and reversed the lockout.Good luck
Posted on Mar 19, 2010
    President:
  • 1,284 Answers
RCA 20F420T FPA lock - a322d6d.jpgIt looks like you will need the RCA remote to unlock the FPA (front panel assembly). Hopefully you have one.
Posted on Jan 22, 2008
    New Friend:
If you have Direct TV and their remote programmed to the TV this worked for me. Switch the Direct TV remote to the TV mode. Press the menu button. This brings up the RCA True Flat TV's menu. Using the chan/page button scroll down to preferences. Press the select button. This brings up the Preferences screen. Scroll down again with the chan/page button to FPA lock. Press the volumn button to select off. Press exit and then switch the Direct TV mode back to the left Direct TV mode. You are done.
Posted on Feb 19, 2010
  • Jessica Musick Oct 13, 2011
    I tried this with my direct tv remote and every time I hit the select button the pop up menu disappears. help please.
    New Friend:
Omg sumone plz help me!! i cant figure out how to unlock the fpa lock on my tv... ive tryed everythang.....
Posted on Apr 16, 2010
  • odbayar86 Aug 15, 2011
    i had the same problem on my tv, this is what i did to solve it: on ur universal remote control find the tv's code and configure it so ur remote is set for ur tv. to do this read the manual and the code list from ur universal remote control
    after that u can just access the tv menue from the remote and turn off the fpa lock. hope this help solve ur problem
    New Friend:
Ok so what if you don't have any remots to the tv is their a way to unlock with the tv front panel if not I'm done for....
Posted on Aug 06, 2011
The solution is here http://specs.retaildeck.com/CACHE/FILE7065.PDF
search for FPA and you'll find how to unlock it :)
Posted on Jun 27, 2008
SOURCE:
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Sep 27, 2010 | RCA 20F420T 20" TV
FPA LOCK IS ON AND I HAVE NO REMOTE FOR THE TELEVISION,,, HOW CAN I FIX THIS?
You will need an RCA Remote or Universal (RCA) may work. Once the Front Panel Assy. is locked the TV will only Power on with a remote. Call an Authorized RCA warranty service center, and offer to leave a deposit for the use of the remote. Power the TV on with the remote. Press Menu on remote. Press CH- (down) button on remote to highlight "Preferences". Press OK button to open menu. Press CH-(down) button to highlight "FPA Lock". Press Vol.+ button to turn off FPA Lock.Press Menu button to return to Main Menu. Press Menu button again to clear On Screen Display.
Dec 23, 2008 | RCA 20F420T 20" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
FPA Lock
just get a universal remote... it will work just fine.
Jun 10, 2008 | RCA 20F420T 20" TV
FPA lock
hi i have a universal remote and my granddaughter pressed a button on the tv and now i need to unlock the fpa can some one please help.
Mar 08, 2008 | RCA 20F420T 20" TV
FPA LOCK IS ON HOW DO I TURN IT OFF?DONT HAVE REMOTE . HAVE A UNAVERSAL REMOTE
You will need an original remote I'm afraid. Cannot be done with a universal remote.
Jan 18, 2008 | RCA 20F420T 20" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
FDA Lock
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Aug 21, 2007 | RCA 20F420T 20" TV
RCA 20F420T 20" TV Logo
10,669 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
