Monitors
Problem for Monitors
Generic problem for all Monitors
Monitor
By segomarani on Jan 21, 2008
dead
Same Problem
Nov 22, 2008
-   Turned L1720PQ off will not come back on, nothing at all. I removed the cover of the LCD. There are no noticable issues all capacitor look good. Any ideas?-   dlekang
Best Solution
posted on Feb 20, 2008
Very Helpful)
kishkane
Rank: Wiz
Rating: 76%, 162 votes
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
need to remove the rear panel of this xa3-17b monitor to replace data cable which is broken near the... (More)
Answer
I need Philips 105e Crt Monitor Rgb Cable Pin Diagram
Answer
what to do when your screen goes black and says analog
Answer
I have a Dell Optiplex 360 computer with a service date of 9/7/09 that operates on the XP system. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Tulsa, OK
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
