Plasma TV 99 times out of 100 this tv turns on with only the sound, then after approx 30 seconds there is a click and the sound turns off as well! If the tv does switch on properly it works perfectly! Any suggestions please?
  • kerbside Jan 21, 2008
    Tried this it has made no difference thankyou!
  • 3 Answers
This usually means that the TV was last shutoff by using the sleep timer. When that happens it usually needs to be turned on and off 2 or 3 times, or try using the main power button on the tv or simply unplugging it. A full reset probably wouldn't hurt either.
Posted on Jan 21, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly. > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from
Jan 13, 2016 | Samsung Televison & Video
Plasma screen does not come on and power supply board is bad
When the Plasma TV is plugged in, there're a fewindications of normal operation. Knowing this will help usunderstand what's going on with the unit when anabnormality occurs.1.There is a click from the relaysRL402andRL403when they are activated.2.The LED in the Optical Jack inside the DT board turns on for approx. 4seconds.3.Immediately after that, one of the Tuner LEDs (Right) turns on(Solid Red)for approximately 20 seconds.4.The LED in the Optical Jack inside the DT board turns on again for approx.1 second and both LEDs (tuner and optical jack) turn off.5.Then you will hear another click from the relaysRL402andRL403indicating that they are no-longer engaged. (Note: At this time the Tunerand the Optical Jack LED turn off.)5
Feb 06, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
Feb 17, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
My TH-50PX70A Plasma TV, has lost its picture and only has sound. When you turn it only the green power light flickers on and off rapidly (approx 15-20 times) the TV switches on to a dull black and the...
The most likely issue is that the Power Supply has burnt out, you were able to let it cool at get it to work for a while, but perhaps part of the board has melted enough to cause a short. Repairs will cost approx. $300-500.
Jan 13, 2011 | Panasonic TH-50PX70 50 in. Plasma TV
My Visio 50" Plasma Model# VP504FHDTV10A was purchased in June of 2008. Recently when I try to turn it on, it makes a click sound and then the Visio emblem turns a dull amber color and the TV will not turn...
I just solved this kind of problem with my VIZIO VP504FHDTV10A. It was main power supply that went bad. You need to open back panel cover and right in the middle you will see two powersupply boards(subpower board(smaller) and big main powersupply board). Just get board part/model # and search it on eBay(what I did). It was approx. $100. Good luck.
Oct 06, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
Nov 06, 2008 | Televison & Video
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
