Dell Latitude D610 Laptop Computer  - Intel Pentium M 750 1.86GHz, 802.11b/g Wireless, 1G  PC Notebook Logo
Posted on Dec 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Latitude D610 goes off after booting to XP. Changed RAM,Changed Battery,Changed battery, Changed Harddisk,Changed OS..All to no avail.
Anonymous
Level 2:
Sergeant:
  • Expert 244 Answers
  • Posted on Dec 15, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
244
Questions
0
Helped
54564
Points
595
If you are still covered by the warranty, tell dell techsupport all the parts that were already replaced, and i believe the next part that needs to be replaced is the Motherboard, and heatsink. Hope this helps
1helpful
Dell latitude d610 upon boot, msg "The file nvrd32
You need to reinstall your operating system.
If you encounter this while installing XP, then you need to use another CD
3answers
When I try to turn on my Dell D610 Laptop it immediately shuts off.
Hi
Try to remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON, see what happens
Please tell us your results
Good Luck
My Dell latitude will not re-boot
Did you check your battery LED light or Motherboard?
May be you need a dell latitude d610 battery?
This article can solve your ac adapter problem.
http://www.laptop-junction.com/toast/content/dell-ac-power-adapter-not-recognized
My dell d610 sometime powers up in to xp then just freeze them sometime just 3 geen lights flash then nothing can you help
If there is a power issue, the first thing we need to determine is if it's the power adapter or the battery. Is there any difference if:
- You boot up with the battery in but the AC adapter not connected?
- You boot up with both the battery and AC adapter connected?
- You boot up with the AC adapter connected but the battery removed?
If different things happen for each of these scenarios, the problem is either a faulty power adapter or battery, depending on which one you can boot up without.
1helpful
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Where is the second battery in a Dell D610 Lap top?
The Second battery on the D610 goes in the Media Bay in place of the Optical Drive.
http://www.partstore.com/Part/Dell/Dell/9X001/Refurbished.aspx?s=froogle
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
6helpful
4answers
4helpful
4answers
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
2answers
Setup bluetooth
Hi
The D610 does not by default have bluetooth it does have an icon for bluetooth on the mold if your system does have bluetooth the dell web sight has drivers and software to install and set up the use also with you are using windows XP SP2 has some bluethooth options you can enable in windows control panel
more info on the dell update page
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D610&os=WW1&osl=en&catid=&impid=
Look under network
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
