Question about Kyocera Switchback KX21 Cellular Phone
Application Error , Memory Access Error, Unable to save to phone...
The subject line contains the messages I get on my phone when I try to create a personal ringtone and download it via wap.phonezoo.com .
I don't know why it won't save the ringtones
they aren't big in size.
Basically it will not let me download ringtones from the net
  • himikey9 Jan 23, 2008
    i got the same prob!, im goin nuts!!
  • Mythadrall Mar 20, 2008
    Same problem here, I should note my carrier is MetroPCS.
Me too! ugh! I used PhoneZoo. Idk why it is not working
Posted on Feb 10, 2008
6ya staff
SOURCE:
How to clean rootfs in nokia n900 ?
use purge for installed apps. And dpkg -l ' grep ^rc (this command will show you a list of apps configuration files still left in the system from uninstalled app)
dpkg --purge <appname> (This will remove it)
Performance Chip
May 22, 2012 | Nokia N900 Smartphone
Tip
Backup SMS Messages In Windows Mobiles With Imap SMS Backup
There can be an instance in your life, when you might delete any single SMS or all the SMSs in your mobile phone by mistake. And worst of all, you needed them badly. They were important and now they are disappeared into a thin air. You can easily save yourself from facing such a situation in case you are proud owner of a Windows mobile device. SMSSyncUp is a WM application that will help you to sync up/backup your SMSs to your gmail account from your device.
How To Use SMSSyncUp :
1. Install it
2. Choose your Gmail Account.
3. Open the application, and fill the Send To: with the gmail id to which you want to backup sms.
4. Go to Menu “Login”(it is not an actual login, you need to configure your Gmail account for it).
5. Login should enable the SMS folders dropdown with all your SMS folders.
6. Select the folder to backup.
7. Go to Menu “Sync SMS Folder”. This should start the message conversion to mail format. Progress will be displayed.
8. On completion it will prompt and then ask you if you want to sync.
9. Syncing would send Emails with Subject IMAPSMS| :Sender and the body will contain Message and time, the subject should help you to create proper rules in your gmail account.
on Mar 03, 2010 | Cell Phones
Ok, if try to open my Contacts I'm getting an error message saying "Not enough memory to perform operation. Delete some data first." I am getting this same error message on virtually every...
since you tried everything..let me give yu the ultimate solution
1.go to file manager and backup phone on memory card and remove it
2.go to settings<phone managment<factory settings
3.enter password and reset the phone
4.after resetting insert memory card and restore
Mar 05, 2011 | Cell Phones
I have an N70 Nokia mobile, to create a new SMS or save files to the mobile it showing the error message "there is not enough memory to perform this operation".The memory card contains enough free space...
go to message settings and check the location of the message storage if its on memory card then select to phone memory if its on phone memory then change its to memory card...if problem not solved then reset your phone setting
Aug 29, 2010 | Cell Phones
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory full error when trying to send a mms
you may have to format the memory card by going onto extras then memory card and then format memory card that didn't work so i put it in my sisters phone and formated it there and put it back in my phone and it worked
Jun 08, 2009 | Motorola Mobility MOTO U9 Pink Cellular...
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
Phone cannot access memory card
wipe your MMC card metal contacts carefully and insert it again, this happen beacause your mobile cant able to detect MMC from tour phone one big reason behind that is there is thin layer beatween MMC metal contact and phone cocnnectors contacts. so wipe that metal contacts of MMC and your problem will solved.
Apr 07, 2007 | Nokia 6682 Handheld
System error of memory card
I had a 3650 and I get this error often. What I do is visit the celfone shops and have the operating system reinstalled. There's not much you can do on your part as every button you press leads to the system application error.
May 29, 2006 | Nokia 3650
Kyocera Switchback KX21 Cellular Phone Logo
82 people viewed this question
Top Kyocera Cell Phones Experts
Jeffrey
Level 1 Expert
Mufaddal  Kurlawala
Mufaddal Kurlawala
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
