Question about Sony Cyber-shot DSC-W30 Digital Camera
W30 -USB connection
When I connect the W30 to PC using the USB cable it says "Not identified device" in PC , I tried changing the cable but failed.
How can I get this solved?
    Scholar:
  • 51 Answers
Load the drivers/software from the Sony CD that accompanied the camera and try again. You might also consider a USB connected flash drive "dock" for downloading rather than using the camera. They are not very expensive.
Posted on Jan 22, 2008
Restart a tablet when it is locked
  • Connect the tablet with USB cable to the PC
  • Open the command prompt
  • Change directory to the android SDK platform tools (Type in cmd--> cd C:\Program Files\Android\android-sdk\platform-tools)
Type following commands in cmd
  • adb devices (verify device is identified by pc. If not reconnect device and try again)
  • adb shell
  • adb reboot
It will restart.
Feb 12, 2014 | Android 4.0 Tablet PC
Help! XP stopped recognizing my external hard drive. It has worked fine for two years and then suddenly: My Laptop no longer "dings" when I plug in the external hard drive. There are no unknown...
No question is silly dear, problems are there and we are in this site to help.
Yes, you mentioned that the said device works fine with your desktop, then it is probably not the problem with your device. You have also said that your tried formatting the os. Good.
Hope your pc, laptop and the memory device are disinfected with a good, licensed and updated antivirus.
Check, if Universal Serial Bus Controllers (corresponding to the nos. of total usb port present in the machine) are present and enabled both in the device manager and the bios as well and set to Hi-Speed if it is Full-Speed.
Well, have you tried formatting the memory stick/device? Format it and see if it works.
Next, please change the usb connectivity cable using/attached to the device and see.
Another thing while connecting an external storage device like ext-hdd. The external usb storage devices that gets connected with a usb cable, in some rare cases needs to be connected as a usb-master or usb-slave [you can see many external usb drives comes with a splitted or dual usb port connector cable, this is either for connecting two usb device or to connect as master when used as a single drive], therefore use such cable to connect and use alternated ports, and see which works.
Now, if all above fails, it then might be the problem with your external drive, i guess.
Best to seek help of your system admin/vendor.
Oct 16, 2011 | Microsoft Windows XP Professional
How do I turnon the USB on the westell 6100 modum?
f you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
Sep 06, 2011 | Westell Wirespeed ProLine 6100 Router...
When I connect my samsung monte c3200 phone with pc through cable it says USB device not recognised. I set it to seting > pc connection > ask on connection. Blue tooth is off. Already...
Plug your usb cable into your computer available usb port.Check for the hardware specification, like usb 1.0, usb 1.1. or usb 2.0. Try also installing your device and kies applicatin to other computer to identify or to troubleshoot where exactly the problem. Good day
Nov 30, 2010 | Samsung USB Interface Data Cable for...
My External Hard Drive is asking me to format. Why is it and i currently have information on my external hard drive.
I guess you are using it thru USB...
This is a general issue with all external devices connected thru USB, many times the USB reacts to an external device as though they dont exist.
The best solution is to shutdown the PC remove the device from the external USB port clean the connection, the USB cable connector, USB port etc and reconnect.
This situation could also happen if you have dropped the device, any little shake/**** could make changes to the internal system of the disk.
Try using a different USB cable to connect it to the PC
My personal experience is..... USB devices should be used sparingly and for things that are not critical like (MP3, mobile, camera etc) I rarely use external harddrive thru USB, never to store critical data.....an issue ever with the disk the data is almost gone unless it's recovered by an hardware expert after opening the drive and thru special system/data recovery devices.
The last option is to format it again, many times my MP3 player has been funny and gave me similar read issue and I had to format it many times to be read again by the PC, so i learnt a leason from that......never to connect a harddisk from USB, it's better to have larger harddisk inside the PC and use some DVD disks to carry your critical data to the place of work....(they cost less also) if they fail just throw them and use a new DVD disk
Nov 18, 2010 | Computers & Internet
HI Sir, My Samsung Corby F339 Mobule is not connect in my pc showing error 692 there was a hardware failure in the modem(or other connecting device) plz help me.....
This error usually comes when you use usb cable to connect the phone to pc . Please try to unplug the cable and plugin the USB cable to another port and try via pc suite to connect to internet. If still it is not working try to connect on another pc via same USB cable to phone. If you are getting the same error still then this means the USB cable is damaged then change the USB cable and you can connect to PC. If USB cable works with other pc then reinstall pc suite or try connecting by creating dial up connection.
May 24, 2010 | Lands Phones
My computer not reading device1430 magellan
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
Aug 09, 2009 | Magellan RoadMate 1430 GPS Receiver
Computer does not recognize it
good luck
Aug 03, 2009 | Magellan Maestro 4040 GPS Receiver
Pc suite identifies my LG cu920 phone when
LG PC suite is really quite useless for the VU. Try using just a data cable attached to the phone and usb of your pc. The pc will identify your memory card as an external storage device and you can move your files from the card to your pc. You do nee to have a mamory card installed of up to 4 GB.
Jul 02, 2009 | LG Vu CU920 Cellular Phone
Connection of p910 with PC through DCU-11 failed
hi sounds like you need more configuration to the connection look here in the manual for connecting to other devices: http://www.sonyericsson.com/downloads/P910a_UG_R2a_AE.pdf page 134 and 154 (cable) good luck
Feb 27, 2006 | Sony Ericsson P910
Sony Cyber-shot DSC-W30 Digital Camera Logo
106 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
