Question about Seagate Internal Hard Drives: ST3160021A 160GB Ultra ATA100 7200rpm 2MB Hard Drive (HDST160BV)
Format Error Good Day Experts! I have a seagate hardisk (ST3160021A) 160GB, which im using over a year. It was partition in 2 sections, 20GB for the system(OS) and the rest was for my data. Until such time my system hang-up and since i have a back-up using the symantic ghost, i tried to restored it. After restoring the system its still encountered problem, it can't finish loading the WindowsXP file and it prompts many error. Had tried to restored again and problem still occured. Had decided to remove the partitions and format the whole drive but it will not continue to format and it prompts "format error". Hope you can share your expertise regarding this problem.
  • phyrex Jan 24, 2008
    Thanks a lot Peepnklown & Benimur. Below are the results of your suggestion. Anyway i already informed our local distributor and claim for warranty. Had also found out that warranty of this HD will expired on 2010.
    Peepnklown,
    Had tried use the seagate tool and found that the HD failed on both test, the short/long drive self test and short/long generic test.
    Benimur,
    Had also tried your suggestion but i did it on the same PC with new HD and connect it to secondary master. I was not able to performed the scandisk hence it fails already during formating. I think you are right that this is a hardware fault.
    Thanks a lot and more power,
    phyrex
  • Frank
    Frank May 11, 2010
    I would test the HDD with SeaTools:
    http://www.seagate.com/www/en-us/support...
    Brigadier General:
  • 6,966 Answers
Most "Format Error" messages are generated because of hardware fault. This unfortunately would mean that your ST3160021A is no longer usable.
Alternately, you can try temporarily installing it to a 2nd PC and perform disk utilities on the said HD. Things you can try are partitioning or deleting existing partition, formatting and scanning to check for any bad sectors. You can install the ST3160021A as a primary slave, secondary master or even using an external USB to IDE/SATA adapter such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter.
Once you have verified that no sectors are damaged and that the HD checks out, you can reinstall in the original PC and proceed with Windows installation. If on the other hand errors do occur even with using the 2nd PC, you have confirmed that indeed the HD is defective and would require a replacement.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 21, 2008
  • Louie  Role
    Louie Role Jan 25, 2008
    Glad to be of some assistance.
Im copying a game that is 5 Gb and my free space is 160Gb why does it say that the "there is no disk space" is there anything i could do?
1.plz check your hardisk about any virus..
scan your hardisk a good antivirus
and check your partition type FAT or NTFS, FAT32 only support maximum file size 3gb
if FAT32 please convert as NTFS.
please letme know this helpful
Feb 01, 2011 | Western Digital WD Passport 250GB Portable...
I'am not able to for mat my hard drive
Hi.formatting a hard drive means you will wipe it clean of any files ect, you have on it.
1 On your pc go to the Start .
2 Right click on My Computer and select Manage.
3 Under Storage click on Disk Management.
4 Find your hard disk in the list and right click on it and select Format.
5 Click on Perform Quick Format if you want.
6 Click OK and confirm your OK with losing all data on the drive.
7 Now your done.
Hope this helps.
Regards Bill
Feb 26, 2010 | Seagate Internal Hard Drives: ST3160021A...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Hard disk drive in slave position
Check your jumper settings... Following link is for your hard disk ST3160021A instructions.
http://www.seagate.com/images/support/en/us/cuda_sata_block.gif
Good Luck :)
Feb 21, 2009 | ASUS P5GD1-VM Motherboard
HDD Has been stop be detected in my computer,PLZ HELP!!!Somebody!
try plugging the hard drive into the other ide port on the motherboard
Oct 27, 2008 | Seagate Internal Hard Drives: ST3160021A...
SEAGATE HARD DISK DRIVE PROBLEM...
just remove the jumper settings of the HDD like this one.;
choose the master without a jumper.
let me know
Oct 04, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Formating hardisk with sata connection
1) Be sure that your motherboard support SATA - See Bios
2) Using the Win XP installation CD you can format the drive. If you cannot load windows during the installation hit F6 to charge the SATA drivers.
If your sata drive is working like a second disk, you can format it directly from windows.
Start>> Control Panel >> Admistrative tools >> Computer Management
Or using any partition tools...
Sep 23, 2008 | Seagate Computers & Internet
I am venturing a guess, but it could possibly be your memory and not your hard drive.
Additionally, you can partition and format the 40Gb HD in a second PC using a third party utility such as Partition Magic which would also allow you to verify the integrity of the hard drive
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Apr 01, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate Internal Hard Drives: ST3160021A 160GB Ultra ATA100 7200rpm 2MB Hard Drive (HDST160BV) Logo
340 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
