Question about Fujitsu Siemens AMILO Pro V7010 Notebook
AC power socket breaks of V7010 laptop
The AC power socket at the back of the PC is broken inside. I need to know what to do or need to get service manual to dis assemble the laptop.
thanks
  • 4 more comments
  • butich Jan 21, 2008
    thanks, I thought would get free service. your service is no more required.i've solved it.time is money!
  • catgate Apr 29, 2008
    Same problem. Ac socket broken and left inside machine.
  • dales walker Jun 12, 2008
    computer will not power up, a/c adapter output ok,after removing all the screws unable to lift the keypad to check the a/c input connections,where some problems seem to occur.
  • tcrichton Sep 25, 2008
    Same problem...
    Any tips on how to solve it?
  • tomacha Oct 14, 2008
    same problem
  • subhan222 Dec 15, 2008
    same problem
  • 81 Answers
Glad it worked out for you.
Posted on Jan 21, 2008
Broken internal power connection on gateway p-631-hsn
I recently repaired one of those with a radioshack plug and socket. If it got bumped somehow, it most likely broke the socket inside. You have to follow all the screw which are marked in length by milimeter. First is getting off the trim around the keyboard which snaps on. This is hard to get apart without breaking. Once you get that, the keyboard should have 2 screws and screws do release everything else, piece by piece. I think I have some pics of the one I did, if I can find them it may help you.
Feb 21, 2013 | Gateway Computers & Internet
V7010
have you gone through the manual ..........
Jun 26, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Intermittent fault (poor connection) on 4.8mm 18.5volts power socket on hp presario a900
It sounds like you just need to replace the laptop's power cord/charger because it's not making a good connection any more.
Jun 26, 2012 | HP Computers & Internet
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
Ac socket brocken at back do not knowhow to remove case
Save yourself the headach, and take it to a techie and let him fix it for you. I do it all the time for $60us + parts cost.
Mar 19, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Gateway m-6834 battery light blinking red and won't turn on
Either:
A) Bad battery
Easy to check, take it out and try to boot. If yes. Get a new battery.
http://www.shopbattery.net/gam6mselirel15.html
If no.
B) Bad AC adapter
Does the power brick have an LED on it? Is it on. Even if it is it may not be putting out voltage. If the cord gets bent alot it can break inside so it looks normal. If you or some you know has a MultiMeter , have them check the voltage.If you know someone with the same laptop, try theirs. If it works get a new one.
http://www.buy.com/retail/product.asp?sku=209143953&listingid=29869055&dcaid=17902
C) Broken connector inside laptop
If a known working AC adapter doesnt work there could be a broken connector inside that needs to be resoldered or the power subsystem on the board could be fried.
Mar 04, 2009 | Gateway M-6834 Notebook
Don't Swith 0n
so ac supply is ok battery is ok then mother board is dead i worry pls check it out
Dec 12, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Dv1000 power problem
This is a common problem we faced especially for home users. The problem is really simple: The power adapter socket on your laptop's motherboard is broken. Assuming that the system board is not broken or cracked, this broken socket can be easily replaced. And it only costs $2!
Unfortunately, it is common policy for service centers nowadays to replace the board for this type of problem, thats why they are charging $398, which is actually a good price.
If you have any basic electronic background, then you can replace it yourself. The main hurdle you will face is in finding the exact dc socket and disassembly and assembly of your notebook. Just remove and replace the defective socket from the mainboard. Otherwise you can put external connector on it. It might not look good, but you do have a working laptop now.
Regards
Nov 13, 2008 | HP Pavilion dv1000 Notebook
Amilo pro v7010 laptop wont switch on
If so, unplug it from the wall charger, remove the battery and wait 5 minutes. Then plug the unit back in, leaving the battery out. Attempt to power up. You may lose what work you hadn't saved from the previous use, but nothing else.
If that doesn't work, it's possible that
A) power socket isn't completely connected to the motherboard anymore, so
B) battery isn't charging properly, or
C) the wall charger has gone bad.
I'd say you're in hibernation tho.
Good luck
Nov 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Computers & Internet Logo
304 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
