Question about Hitachi 27CX7B 27" TV
My TV cannot turn ON
After i press the start buttom i can only here a sound "tik" in second.
My tv cannot turn on. I suspect something wrong on 5Volts.
No supply going to plyback.
    Sergeant:
  • 395 Answers
1 check for short on HOT (horizonal output transistor) or bad flyback transformer. 2 check the AC voltage on the relay switching side. if AC voltage is not present on both pins and the relay is engaged replace the relay.3 check for shorts on voltage regulators you will need a schematic for this.
Posted on Jan 22, 2008
Magnavox model 2006. When turned on, why does it make tik tik sound and turn off?
There could be internal arcing causing the tik tik sound. The power supply may have failed.
Sep 16, 2015 | Televison & Video
Honda Civic 2006 ignition issues
99% it's a bad battery.
Sep 16, 2017 | Cars & Trucks
Sony kvef34m61 tv
there is something sparkling on your power supply, check your bypass capacitors on your power supply..
Sep 09, 2013 | Televison & Video
Lg 50pq20d plasma tv not switching on but voice comes out
Aside from checking the fuses it likely will require a technician or a shop to examine the set to see what is wrong and what needs to be replaced.
Sounds like a power supply issue but that would need to be checked.
Jun 10, 2012 | LG 50PQ20D 50 in. HD-Ready Plasma TV
How a engine works
sounds like the plugs where to long and the pistons hit them when you turned the engine over
Apr 28, 2012 | Cars & Trucks
Tik tik sund from philips tv
when i turn on my philips 20 in flat tv i have no picture, just black screen with a tik tik sound
May 11, 2010 | Philips Magnavox 27MS343S 27" TV
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
When I switch on my Sony Trinitron Tv , it won't turn ON , only the red LED flashing in front next to start button , and sounds tik tik. Please advice .
take your tv to a repairing shop and let your technician check the power supply section is not producing an ht to trigger the line transformer, in turn various voltages will be produced, which will open up your tv.
Feb 26, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Automatic sutdown monitor on runing pc
This is in your pc its the power savings in settings on your pc goto screen saver then powr settings try that. also is that movie or movi? the whole thing didnt make sense. maybe also integrated graghics issue
Nov 25, 2006 | SAMTRON 55V 15" CRT Monitor
No Power to TV
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Nov 08, 2006 | Zenith C27A24T 27" TV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
