Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Does the repair & cost recommendation solve our problem?
Our 65" Hitachi Ultra Vision Projection set (4yrs. old) has a blue wave in the upper left hand corner. The picture also changes from color to blk & wht & back again. The tech recommends a replacement of the conversion generator & possibly 2 resistors in the blue circuit, after trying to adjust the grides for an hour.( $700+ is the quote). Yikes- to repair or to replace after only 4yrs, are parts that expensive or that marked-up?
  • 1 more comment
  • grandmaleen Jan 24, 2008
    Thanks for trying..unfortunately, the tech is saying he is unable to adjust the blue color or blue color grid in our set.
    He wants to order & states we need a conversion generator & possibly 2 resistors &/or diodes replaced on the circuit board.
    I know resistors &/or diodes are small components & are usually inexpensive, but a conversion generator???
  • martha_lugo Aug 25, 2008
    My 52 projection TV has a blue film transparent at the bottom replicating the image - How much does this cost? Panasonic TV help I need a technician with a moderate price. Hayward
    I don't want to spent a lot of money.
Please call email a quote on a Panasonic TV projection with a blue film at the bottom. It duplicate the bottom image. Conversion
I don't want an expensive repair. What is the quote?
mlugo@housingeducation.org
Posted on Aug 25, 2008
  • Hitachi Master
  • 5,138 Answers
I hope they are not your only repair shop around ,if i where you i would call another repair shop ,that is way to high for repair cost if they are only changing out (2) STK-392-110s, cost 90.00 also if they happen to be STK 392-560s the price of those are only10.00 differents also price of resistors at most 4.95- how much is bench labor?550.00 dollars wow!!!!! I think you were trying to say convergence chips if im right all the above is true. let me know if this is what they are telling you.I do this same job at my shop cost (2) stks 110.00 plus tax 8.80 plus labor if i do not run into hard time to realine 225.00 total cost 343.80
Posted on Jan 21, 2008
  • ladywinn
    ladywinn Jan 24, 2008
    Dear Grandmaleen, here in alabama we have a saying THAT DOG DONT HUNT !!!!!!! You keep saying conversion generator,there is NO conversion generator part in a TV, I know ive been doing tv repair for 32 yrs.However there is equitment used to set convergence on Televisions BIG diffence in part and equitment. Part used to fix convergence problems (2) STK392-180s
  • ladywinn
    ladywinn Jan 25, 2008
    this answer should have been rated FixYa.
Not positive of model # Bought new about 10 yrs.Definitely 42, HDTV, projection. Hitachi. Remote says: CLU-5713TSI. Blue sine wave-like streak at top left quarter of screen. Attempting Digital Array...
You have described a typical convergence problem. It takes skills in unsoldering and soldering to get it fixed. There are two convergence IC's that need to be changed and possibly a resistor if open. You have to determine if the picture before it went out looks good enough to spend money on. Typically the parts, technical charge and service call will cost you on average of about $300. However, since the set is already 10 years old I would venture to say that the tubes are getting weak and does not have much life left in them. I would recommend upgrading to an LCD or LED television for just a few dollars more. If you take on the project yourself, I must tell you that you need to be proficient in electronic soldering and unsoldering. The IC's are mounted side by side on a metal heat sink and are about 2 inches by about 4 inches and are soldered in with 18 pins each. Use desoldering braid to remove and when solder the new ones be careful not to bridge the pins with solder. Also when unsoldering care must be taken not to break the printed circuit. And look for a burned resistor which is a cylinder shaped object with metal wires out both ends and going into the board. You can identify the value of the burned resistors by comparing the ones that are similar in the circuit and are not burned. Usually there are two side by side
Dec 08, 2011 | Hitachi 42V710 42" Rear Projection HDTV
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
Hitachi 53udx10b screen is dark, very blue and red. there is a red wave across the top of the screen. there is a blue "ghosting" of any text on screen.
The tv have a problems known as a convergence picture problems,it is dead.Tv set have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to causes all these problems.Now the tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set convergence pictures promblems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Hitachi 43UWX10B 43" Rear Projection...
There is a wave (color change) on the upper left hand corner of
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS,and all it resistors to solved this problems.Buy a convergence kit to fix it ur self.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost U $300 for parts and labors.
Feb 06, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I get a split up of red and green in a wave at top of screen
The convergence ICs and resistors are the most likely things to cause that. You can get the convergence repair kit for the DP14G hitachi( 53UXX10B) at the following link which contains the parts and instructions.
http://www.tvrepairkits.net/
Jul 11, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 53SBX10B Projection TV
that is a convergence fail. would need dome new parts and board rework. expect somewhere in the neighborhood of $200-$500 for repair from most tv service centers.
Feb 20, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Blue Yellow Wave
I believe what you have is a convergence problem and it is usually caused by two Integrated Circuits going bad which also opens up one or two resistors associated with them. Replacing the Convergence Ic'S - (Ik04 & Ik05) and Resistor Rk62 a 1.8 Ohm .5w. Metal Film type should take care of the problem. As far as costs involved, I would guess about $350-$425 to get repaired. With it only being about 4 years old, it should have that many more years left of good use for you.
Mar 11, 2007 | Hitachi 43FDX01B TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
149 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
