My brand new Emerson under counter EM83701 coffee maker cannot be filled with water. The water reservoir, when removed from the coffee maker itself, is open at the bottom. The spout at the bottom of the reservoir, which plugs into the rubber receptacle in the coffee maker itself, is a straight, open conduit, from which the water will, of course, pour freely. I'm guessing there is supposed to be some sort of a valve at the bottom of the water reservoir, which prevents the water from pouring out until it has been plugged into the coffee maker, but nothing of the sort is there. Curiously, the parts all fit together so well, that I'm having trouble imagining how you could fit a (presumably missing) piece into that space, anyway!
What should I do?
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 11, 2008
Same problem. Did you get a valve or something to make it work? They must have made a lot of them with this problem
My coffee maker has an 18 month warrenty.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Emerson EM83701 Coffee Maker
Email this problem
Can you Help with these Coffee and Espresso Makers problems?
repair to delonghi coffee maker...
kenmore coffee maker . press...
Just purchased, didn't come...
