Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
Asus Board MOdel Number P4BGL (845 Mxl) is giving an error called Chasis opened or tampered.?
  • 2 more comments
  • sanju5750 Jan 21, 2008
    Asus Board MOdel Number P4BGL (845 Mxl) is giving an error called Chasis opened or Tampered
  • satyasafar Dec 16, 2009
    how to cmos clear
  • Emelio Navaja
    Emelio Navaja May 11, 2010
    is this windows pop up errors or in the bios error?
  • 1,226 Answers
I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
" 9. anonobomber, 07-05-2002 09:51 read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check for the manual pertaining to your motherboard"
Posted on Jan 21, 2008
  • 106 Answers
Hello Dear... From
Ganesh A
"Chasis opened" message is not a problem man.It indicates only the system box had opened previously.This is for your privacy;You can solve it easily.follow the steps...
1.Restart the system using reset button on your cpu (or) restart the computer
2.Press "Del" key frequently to get the cmos setup (Some systems use F2 or F10 or F12 Key)
Now You can see Blue color screen and some menu items...This is Cmos.
3.Find Out about like "Chasis" word from the cmos Menu(This is done by Press "Enter" button in a particular menu item;
if not found then ,use Esc Key to go back;
then choose another menu item and find out the "CHASIS" option Where it is;surely you can find within seconds)
4.Then Disable the "Chasis " Option.
5.Press F10 to Save the current settings in cmos
6.Press "y" ,then Press "Enter"
Now Your System will be restarted.Also now Your Problem Fixed 100% sure.
Thank you.
Posted on Feb 12, 2010
Can't boot
i should have thank u, if u add some more details in ur query, anyway check the following :
1. check if ur power cable is properly connected and free from damage or broken
2. did u see any blinking indicators on ur front panel
3. open the cabinet and look if the fans are spining
4. did u hear any beeps during (POST) startup
***** if ur answer to the above is YES, then
remove all the power connectors (outside and inside) , all the add on cards, RAM sticks, (and also the processor if u have a pair of smart hand), carefully clean and blow out dusts, and reinsert all of them to thier respective places, and try again.
If u find all these solutions useless, ur processor or RAM or mainboard might defective.
May 06, 2009 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
How to I connect my SATA DVD drive to the motherboard?
Hi Vicrod,
I'll need a better model number than "845" to give you a definitive answer, as ASUS doesn't name their boards that way. I suspect that the board supports the Intel 845 chipset and that's where the 845 comes into play. If you don't have the owner's manual, you'll need to look at the board real close; you'll find the model number stamped on the board. The good news is that if the board was built in the last 3 years or so it should have built-in SATA connectors (at least 2, probably 4 or more). If your DVD doesn't have the IDE cable and instead has a much smaller cable, it is in all likelihood SATA. In the worst case, even if your MB doesn't support SATA, you can buy a SATA PCI card to hook the drive up to for under $30. Finally, you can go to when you get the full model number. From there you can download an owner's manual that will have the SATA ports labeled.
I hope this helps you. If you think it appropriate, a fix-ya rating would be much appreciated.
Oct 29, 2008 | Computers & Internet
Problem with motherboard
When ever I start my computer it directly goes to bios settings and it says *********** board frequency not set properly. I tried with every kind of frequency but it did not work out and also it takes long time to get start.
Mother Board - ASUS P4BGL-MX , I bought this 2004. Please give me the solution.
Aug 30, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Booting Problems 845 GVSR Chipset Motherboard
it is possible to repair,just check the rate if it is costly then you better take a new one
May 15, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
How to repair mother board in chip level
board has getting on but desply not come and cpu surrounding componant not get power
Jan 20, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
845 motherboard driver
try here >>>
Sep 19, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
HD LED and POWER LED Connection
here is a link to the manual that should give you a diagram - - hope this solves your problem.
Sep 17, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
393 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
