Question about Webroot Spy Sweeper (spysweeper) for PC
Program Will Not open...
DL'd free version, and says it installed successfully. When I click to open and run the program, I get nothing-no error message, NOTHING! PC is sunning on Windows XP.
  • 29 Answers
I would uninstall in and then reinstall or another good spyware free program is spybot s&d you can download it here http://www.download.com/Spybot-Search-Destroy/3000-8022_4-10122137.html
Posted on Jan 22, 2008
Can not get Adobe PhotoDeluxe2.0 to install on windows 7. Worked fine on Vista
Adobe Photo Deluxe is an older program that does not seem to be compatible with Windows 7. you should contact Adobe to see if they have an updated version.
However, you can try the following to see if it will help.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1)Right click on the Program
2)Click on Properties
3)Click on Compatibility tab
4)Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 04, 2013 | Microsoft Windows Vista Ultimate Edition
How do i fix windows update error 1722
According to the error code 1722, it is actually a windows installer error. What we need to do is to fix the Windows Installer.
Try the following fix below...
(Please note that before trying any of the solutions below, you must be logged into your computer as an Administrator.)
  • Check whether Windows Installer engine is functioning.
  1. Click Start > Accessories > Command Prompt.
  2. At the command prompt, type MSIExec and press Enter. MSI refers to the Windows Installer.
  3. In the MSI engine is working, you should see no error messages. However, if you see an error message, note down the error. Search for it in a search engine such as Google to find troubleshooting solutions.
  4. Now try to install or uninstall the program again. If the problem persists, go to the next fix.
  • Check that Windows Installer service is not disabled.
  1. Click Start and type service.msc in the Search box and press Enter.
  2. The Services window is opened. Right-click on 'Windows Installer' service, then click 'Start'. The service needs to start without any errors.
  3. Now try to install or uninstall your program again. If it persists, try the next fix.
  • Check for latest version of Windows Installer.
  2. Once the command prompt window opens up, type MSIExec and press Enter. If MSI engine is working, you should see no error messages, and it should open a separate dialog box, which shows the MSI version.
  3. If the installer version doesn't show as version 4.5, download the latest version athttp://support.microsoft.com/kb/942288/
  4. Now try to install or reinstall your program again. If it still persists, try the next fix.
  • Reregister the installer engine.
  2. At the command prompt, first type MSIExec / unregister, then press Enter and type MSIExec / regserver
  3. Now try to install or reinstall your program again.
  • Clean your CD or DVD media.
  1. If you are trying to install the program from a CD or DVD media, use a CD or DVD disc cleaning kit.
  2. You can also gently wipe the silver side of the disc with a soft, lint-free cotton cloth. Make sure you do not use paper or other rough cloth as this can scratch the plastic or leave streaks that can damage the disk. Make sure you wipe the disk from the center outward and not circular motion.
  3. If you use a damp cloth or commercial disk cleaning solution, wipe the disc thoroughly before inserting into the drive.
  • Copy installation files to your computer.
  1. If you are using a removable or external media to install the program, copy the installation files from there to your computer's hard drive and then run the installation file from that location. It is usually called autorun.exe or setup.exe. If you are not sure, just check the Readme file in the setup folder about how to start the installation.
  2. Unless there is no .exe file present in the setup folder, we do not recommend that you run .msi files directly.
  • Terminating other programs running on your computer.
  1. Click Start and type msconfig in the Search box.
  2. One the 'General' tab, click 'Selective startup', then click to clear the 'Load startup items' checkbox.
  3. Click 'Services' tab, click 'Hide all Microsoft services', and then click 'Disable all'.
  4. Click OK, then click Restart.
  5. After the computer restarts, try to run your program installation.
  6. Once you have finished troubleshooting the problem, restart your computer again.
  7. Click Start, type msconfig in the Search box. Click on the 'General' tab, click 'Normal startup', click OK, then click Restart.
    Hope this helps!
Sep 09, 2011 | Computers & Internet
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
I have version 3.0 and windows 7 and it wont load. i see the start screen with the lady on it but nothing ever happens. I really want to use this program like i do on my other pc.
To run the Program Compatibility troubleshooter
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
Sep 13, 2010 | Nova Development Photo Explosion Deluxe...
I GET A 1554 ERROR WHEN i AM TRYING TO LAUNCH PAINT SHOP PRO PHOTO X2
Photo Explosion 4.0 is compatible with Windows 7. but not your version unfortunately.
If the compatibility is not successful, then try and run the Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking the Start button.
Then click Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
Feb 06, 2010 | Corel Paint Shop Pro 9
I bought a new laptop 4days ago and got a free microsoft word 2007 trial with it for 60days.it is now locked and even though i have type in the product code it wouldnt except it.how do i unlock it?
you have to put the disc on the laptop and install the it will ask you product key then you open your ms office disc book and its there inside .then you type in .
Jan 12, 2010 | Microsoft Office Professional 2007 Full...
My music creator 4 wont let me register my product
HI ^^
take this latest version
download the full version of Cakewalk Music Creator 5
Release Name: CAKEWALK.MUSIC.CREATOR.V5-ADDICTION
Download:
http://hotfile.com/dl/7508024/76ecddc/cmcv5.part1.rar.html
http://hotfile.com/dl/7508027/7bd05b2/cmcv5.part2.rar.html
http://hotfile.com/dl/7508026/7b1d1bb/cmcv5.part3.rar.html
http://hotfile.com/dl/7508028/4f36d59/cmcv5.part4.rar.html
Any troubles just let me know
plz rate it FIXYA ;)
Jun 26, 2009 | Cakewalk Music Creator 4
Drivers
This is the best way to download the drivers of all your devices which are connected to the system for free.
But you have to be patient.
First, i want you to download a ree program called "Orbit download manager" from the link below,
http://dl.orbitdownloader.com/dl/OrbitDownloaderSetup.exe
And then you can download a program called "Driver genius" from link
http://www.qwerks.com/download/6776/drvgenpro.exe
it is a trial program for 15 days
dont worry we only need it for 5 minutes
Install & run the program & in the windows click on the update the drivers
It will check & it will give the window with the drives that needs to be updated & it will not update a it is a trial one.
So you just right click on the driver name, you will get a message called 'copy url address 1' copy that & open the orbit downloader & click on the create new download & paste the link the drivers will be downloaded for free.
Some sites give these drivers only for the money & we cannot be able to find them from the free sites, so i think this would be a nice trick.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Computers & Internet
Photo Explosion Deluxe - install
Contact software Mfg. You have FREE warranty rights.
You might try also
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors.
Dec 17, 2007 | Nova Development Photo Explosion Deluxe...
Webroot Spy Sweeper (spysweeper) for PC Logo
Top Webroot Computers & Internet Experts
Mike
Alun Cox
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
