Question about JVC GR-D250 Mini DV Digital Camcorder
JVC GR-D250U (GR-D250US) Safeguard Mode -- Missing screw?
I have a JVC GR-D250U MiniDV Video Camera, purchased early 2006 that locked up with the "Unit in Safeguard Mode" alert problem "06." Problem began late 2006 w/no extended warranty so it was past the 90 day labor and parts, but still in the 12 month part only. After going online I saw that this was a common problem, and I called JVC hoping to get some further assistance than parts only coverage. No joy. Over the phone with JVC I was told it was a "failure of the pulse generator" (?) and told my only option was to go to a service center for warranty work. I called the nearest service center but decided I would soon pay for the unit again in diagnostic and service costs. Thus the unit has sat for over a year in the closet. Today I decided to check if there was anything different online and not finding any new news decided it was time to break out the tiny screw drivers.
At this point, I have found a screw missing. Although I have one-half exposed at this time, the missing screw is behind a tiny grey plastic panel behind the LCD. When the LCD screen is open there is a plastic panel up against the hinge (takes two screws to remove). When I removed the plastic panel I was greeted with four screw holes, two from the screws I removed and two that mount (or keep still/keep in place) a flat cable. In mine, there is only one screw holding the cable down. I am curious if the other fell out. At one point--after the error--there was a rattle in the unit. Although it is possible that the screw was never put in, I now suspect that the screw may have come loose and shorted something out, or became lodged in a mechanism (I would prefer the latter).
Anyone opened a GR-D250U unit yet? If not and you have this same error, I would be curious if you are also missing this screw--it is an easy removal (no tamper stickers) and the LCD screen will flip around so the screwdriver is not near it. I will forge on, may have to pack it up until tomorrow evening.
  • Anonymous Mar 30, 2008
    YO TENGO UN PROBLEMA CON EL MISMO MODELO DE LA CAMARA JVC GR-D250US YA QUE CUANDO LA ADQUIRI NO TRAIA DISCO DE INSTALACION PARA PASAR TODAS MIS GRABACIONES AL PC AHORA YA ESTOY CANSADO DE COMPRAR CASSETTE Y NO LOS PUEDO PASAR AL ORDENADOR ES POR ESO QUE NECESITO UN SOFTWARE O DRIVE NO SE LOQUE ESTA COSA NECESITA PARA YO PODER PASAR MIS GRAVACIONES A LA PC Y GRAVARLAS EN DVD, GRACIAS DE ANTEMANO LES AGRADECERE SI ME LA DIRECCION DONDE YO PUEDA BAJAR LO QUE NECESITE POR FAVOR SE LOS AGRADECERE. GRACIAS
  • nmorales19 Jun 21, 2008
    I came across the same problem with my JVC GR-D250U on the Error 06 Unit in Safeguard mode. I actually followed your instructions CINDINI, and I made a critical observation. The black flat cable was pressing against the microchip board, and underneath the cable was a black square piece of plastic stuck between the cable and chip board. I removed the pinched square piece with eyebrow tweezers, and I popped the cable up after this I did not pop the cable back down instead I left as is making sure nothing was touching the chip board. I took the grey plastic piece that takes two screws and put it back on. I found that it worked, and I have yet to receive another "Unit in Safe Guard mode error." It has been a total of one hour between M, A, and Play modes with no error. I have also turned it off anywhere from 3 to 5 times, and I believe the problem has been resolved. Thanks for your input I would not have fixed it without your posting.
My LCD would only turn on intermittently. I did the same thing as nmorales19. There was no loose plastic in my unit but I did move the ribbon cable so that it folds different and does not touch the circuit board. I did not replace the grey cover since it will get in the way of the ribbon cable now. Now that the ribbon cable doesn't touch the circuit board my LCD comes on every time and I don't have to try and use the camera looking through the crappy view finder!
Posted on Jun 16, 2009
Posted on Jun 21, 2008
  • 156 Answers
E06 means the capstan motor is not working well.even if is working somewere it is stucking.so try to open the mechanisum assumbly and remove screw or some plastic pice in the middile of the teeth which is creating this error.
Posted on Jan 22, 2008
I HAVE A JVC GR-D820EK MINI DV VIDEO CAMERA AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE...
i HAVE A JVC GR-D820EK MINI DV AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE COULD YOU ADVISE
Feb 11, 2011 | JVC GR-D775, GR-D790, GR-D796, GR-D820EK,...
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
I have a JVC GR-D75OU video camera. When I turn
i have jvc movie camera when i turn it on it says protective cap is on how do i fix this
Nov 30, 2009 | JVC GRD775 / GR-D775US / GR-D775US MiniDV...
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
EO1 unit in safeguard mode
Try to replace loading motor
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the loading direction for 4 seconds
or more. This error is defined as [E01].
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA
Jan 09, 2009 | JVC Cybercam GR-D30 Mini DV Digital...
Safeguard mode error 06
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
Dec 12, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
1,694 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
