Question about Symphonic SC313D 13 in. TV/VCR Combo
Symphonic 13 inch tv vcr combo
My grand child has pullled he power cord out of the back we have taken it apart but still cant find a place to put the cord back it was working great until now and just hate to get rid of it
    Scholar:
  • 57 Answers
Solution steps:
1. Make sure that the cable is not plugged into the mains receptacle.
2. Open up the unit
3. Inspect the board. Look out for a glass fuse rated about 3A/220V near one corner of the board. It is close to the mechanical ON/OFF switch on the TV. The cable normally plugs into a socket made up of two vertical pins an inch or less from the fuse. Sometimes these are marked with a squiggle (~) or two (~~) to signify that the mains power goes there.
4. If the cable terminator (end of the cable opposite the mains plug) was cleanly pulled out, then well and good. In that case simply plug it back in. If not (i.e. the cable is damaged, then you may have to remove the terminator and solder the cable directly to the board.
5. To pre-empt any further "pullings", make a knot on the cable inside the TV where the cable comes out so that there is some resistance to the pull.
6. Close the unit and enjoy.
Posted on Jan 21, 2008
Tv/vcr shuts down after 5 secs.
There is likely an issue in either the primary or the secondary power supply that is causing the TV to shut down. Unless you or someone you know is good at repairing switching power supplies, there's not much you can do to save this unit.
Oct 07, 2016 | Symphonic SC-3813 13-Inch TV/VCR Combo
I believe my differential is going in my 97 dodge grand caravan. The speedometer and RPM's went all over the place so i pulled over then it seized up like there might be something wrong with t
Differentials hardly go bad in these. On a rebuild, they are taken out, but not taken apart unless there is noticeable wear or sloppiness. I would say some one didn't put your transmission back together right.
Jan 14, 2015 | 1997 Dodge Grand Caravan
I cant replace my pull cord on my bc30 zip start ryobi weed eater?
On the equipment I have worked on the spring ends are formed into a circle. One end of the spring fits into the pulley and the other into the case. I wind the spring up on the pully just enough to fit it into the case with the cord placed into a notch in the pulley. Then you must wind the spring more so the cord is fully taken up. So to wind it up some more place the cord in the notch and turn it a turn or two till the cord is fully taken up.
Mar 07, 2014 | Garden
Vcr stuck on eject and poiwers off right away
Chances are that something has become damaged inside the unit and as the unit can't get out the tape, powers off to stop any further damage. The only solution will be to remove the video by entering the unit. As this is a TV unit care should be taken of the high voltages connected with the TV part. And should only be undertaken by someone with experiance.
Feb 09, 2013 | Symphonic SC-3813 13-Inch TV/VCR Combo
Child safety lock on 2003 pontiac grand prix
should be a switch on the back doors to turn on and off the child safety locks it requires your key or a flat blade screw driver.. let me know if this works for you
Apr 12, 2012 | 2003 Pontiac Grand Prix
My ps3 will put green dots and other stuff on the screen and then eventually freeze up. ive taken it apart more than a few times now and i cant figure it out. i thought i had the problem fixed the first...
SAFE MODE: Place your finger on the on/off sensor leave it their until you machine turns off then take your finger off, place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off. Once in safe mode select the option PS3 System Restore. NOTE: The system restore will delete all of your saved game data I recommend backing up you system if you can.
Taking you PS3 lid off and placing a fan over the top won't cool anything except the Blue-Ray deck and power supply if anything is causing an overheat it would be under the metal plate that those 2 components are sitting on and even then the overheating is on the underneath side of the motherboard where the heat-sink fan is. If the system is getting to hot it has a safety feature and your PS3 will turn off usually causing the YELLOW LIGHT OF DEATH which would force you to take your console down the motherboard and do a flux and reflow of the board. Good Luck!
Feb 10, 2011 | Sony Video Game Consoles & Games
Where is the plug in on the printer that connects to the computer. I have the white cord and cannot find the receptacle that fits We moved and the printer was taken apart It is one great machine!!!!!!
Looking at the back of the printer, the receptacle is on the left side wall of the indentation below where you put the paper in. It's kind of around the corner.
Sep 13, 2010 | Canon PIXMA MX310 All-In-One Printer
Symphonic SC313D 13 in. TV/VCR Combo Logo
99 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
