Question about Seagate (ST3300601CB-RK) (ST3300601CBRK) 300 GB Hard Drive
Spindles are jammed solid
There was a lightning in the area and all of a sudden i saw sparks flying out of my USB port. Few minutes later i noticed my machine was not reading my external drive. i booted the device and still had no luck. i tried listening to the drive and heard it was not spinning inside.
Took it in for data recovery and found that the spindles are jammed solid.
quite depressing as i lost over 250Gig of my HOUSE music.
I have decided to stay away from Seagate and ordered two Western Digital drives.
  • Sibs Jan 22, 2008
    Thanks a lot for the information I have bought another Seagate 500G HDD Model> ST305004FDD1E1-RK
    Atleast it comes with a five year warranty.
    I appreciate your HELP!!!
    Sibs
    Scholar:
  • 176 Answers
After a surge caused by lighting , does not matter if u use Seagate or WD drives ! And if u can u should check all u're components (if a pc, specially u're power supply) for damage, blackened components or inflated capacitors, because u'll might get later on in time problems and u;ll not know what caused them ...
The data can be still recuperated, if u go to a special data recovery company (they remove the spindles and mount them on other devices) but is expensive. And if it;s just music u lost.... ain't worth it !
Posted on Jan 21, 2008
Why is it overheating after 30 minutes use?
Low oil, dirty oil, clogged oil filter, clogged cooling fins around the engine or fly wheel, Using ethanoled fuel instead of ethanol free fuel, lack of lubrication on blade spindles, rusted dirty or worn blade spindles. Just a few possibilities.
Aug 31, 2015 | Garden
Why does my chain saw lose power and shut off as soon as it gets hot.can't restart until it cools off.
Check coil pic up or the electrical pick up in the pull string housing. Remove that and u will see the fly wheel next to that is the electrical pick up .look at fly wheel make sure magnets are clean surface ,they are in the fly wheel itself.after that remove coil and clean surface that faces fly wheel. Using a match book cover place it between fly wheel and coil ,make sure it moves but not falls out snug ,tighten coil screws and remove match book cover. If it dose it again re place coil look for small engine shop in your area and the can help get u a new one .weak spark means coil,sparkplug
Sep 15, 2014 | Poulan PP4218AV 18" Chain Saw
Circular saw spinning but not cutting wood
Does the blade actually stop when you try to cut or does it spin but not cut. If it is stopping, and the motor is still running then I am afraid you have stripped gears and will need anew armature and spindle gear (sometimes complete with spindle, sometimes a press fit with a woodruff key to locate it). If the motor is stalling then it would suggest that the field coil is faulty, but you would notice excessive sparking from one brush if this was the case. if you get major sparking from both brushes then the armature is probably faulty, or if you are lucky it could just be brushes wearing low and not making a constant contact.
If the blade is spinning and not slowing when you try to cut I would think it is either blunt or mounted the wrong way round.
Sep 21, 2013 | Worx Versacut Mini Circular Saw
I moved my 2008 dodge magnum out the Drive way three hours later i went to crank it up and it would not Turn over at all . I saw a few days before that as i crank it a lightning bolt light showed UP on the...
That symbol means low voltage in the system, you have a dead or defective battery. These new sealed batteries can go out of the blue, starts fine and then a few minutes or hours later nothing, no crank no start. You can confirm the battery is the problem by honking the horn, it will dribble out a noise or not work at all if the battery is dead or nearly dead.
Oct 16, 2011 | 2008 Dodge Magnum
Im trying to set up my router,i have been using it before but my cpu has been damaged by lightning,sinv\ce then i cant use my router. i followed instructions on how to re configure it,my laptop and pc...
sometimes this router are afected by the lightnings, verify that the internet connection is working well by plugin the internet(ethernet) cable directly to your computer, if it gets connected to the internet we are sure the probleme is isolated to the router.
The easiest way to check if the problem is the router WAN(internet) port would be connecting a known good router just for few minutes
Aug 29, 2011 | Linksys Wireless-G WRT54G Router
King Compound Mitre Saw Mod.# 8370 Sawblade always comes loose. Th Blade is installed properly. What can I do ?????
This is very dangerous... There are possibilities of incorrect installation due to IMPROPER parts. Some blades use a diamond cutout for the shaft. It is VERY important that the right size spindle versus blade is used. The washer under the retaining screw should have a relief on the back side such that the washer lets the shaft protrude a few thousandths through the blade. If the spindle is round without the diamond cutout, sudden stops can unwind the screw. I have hadd that problem on a radial arm saw. I would recommend that you get some thread sealant (removable type) such as Loctite and put a little on the threads FOLLOWING directions. Make sure it is the removable type grade of Loctite. Also tighten the screw properly either using the locking pin or jam a piece of wood in the teeth to hold from rotating while tightening.
Jul 28, 2011 | Garden
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
2000 ford escort zx2 will turn over but it won't start!! HELP!!
so you have spark is the rotor button truning when you crank the mtr over. sorry these may seem like mundane questions but this what i need to know. you stated that the timing belt was replaced has the vech ran seens the belt was replaced?
Dec 31, 2008 | 2001 Ford Escort ZX2
Dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Oct 07, 2008 | Saws
Seagate (ST3300601CB-RK) (ST3300601CBRK) 300 GB Hard Drive Logo
85 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
