Question about Canon ZR200 Mini DV Digital Camcorder
Wrong Format Playback not possible for Canon ZR200
I have Canon ZR200 mini Dv. The message "Wrong Format playback not possible" appears, indicates that attempted to play back a tape recorded in HD format. but I have this problem at several tapes, what is the solution??
5 Suggested Answers
SOURCE: No sound or vision playback of dv tape
From my poin of view cyliner (rotary head) have poor conection or this parts will be replace.
Posted on Oct 07, 2007
  • 68 Answers
SOURCE: JVC GR-DVL120 Playback
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
Posted on Nov 20, 2007
SOURCE: Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Posted on May 29, 2008
SOURCE: black lines on playback no playback
hi, if you have stuck the head cleaner in and this has not removed the black lines then the head might either need a thorough clean or may be damaged.
Posted on Jul 23, 2008
  • 1223 Answers
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Posted on Apr 24, 2009
0 characters
1 Points
Why does my ZR200 have horizontal bands on playback
Try setting back to Exposure to EASY and it should work fine.
Let me know if this does not fix the issue.
Thank you for contacting FixYa
Nov 18, 2010 | Canon ZR200 Mini DV Digital Camcorder
What does wrong format mean with a canon zr300 camcorder? My buddy shot some footage on a high end camera and my zr300 camera at playback reads "wrong format playback not possible.
Different camcorders have different recording formats. Some ar HD, some are 16x9, etc.
A camera that isn't designed for a particular pre-recorded format cannot playback that recording.
Sep 06, 2010 | Canon ZR300 Mini DV Digital Camcorder
Recording playback has lines through it.
try with head cleaner tape 2 or 3 times mostly it works if not change video head assembly
May 24, 2010 | Canon ZR200 Mini DV Digital Camcorder
Gray bars during playback. sound comes in and out
Fast forward or insert another tape. Then record something for 15-30 seconds. Then try your playback again. Worked for us.
Feb 05, 2010 | Canon ZR200 Mini DV Digital Camcorder
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
Canon ZR200 camcorder mini dv
Have any of you tried using a mini DV cleaner on your cameras? I'll try this soon and report back.
Nov 27, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200
This is the description of the feature you need: "Have friends in far-off places? Turn your ZR200 into a Webcam for Internet Video Chat with Microsoft Windows Messenger through IEEE1394. It's all possible thanks to the DV Messenger2 software, available as a free download for ZR200 owners. DV Messenger2 allows you to control the zoom and focus of your ZR200 or the camcorder of the person you are chatting with. Preview thumbnails and transfer photos. You can even watch and control the video playback of either camcorder right from your computer." You can download DV Messenger Version 2 only after registering with Canon, see the bottom of the following page: I believe the drivers are included in the download. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
217 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
