Question about Vivitar ViviCam 35 Digital Camera
Load film into my camera
I do not know how to load my film can you help me
I need a copy of the instuction manual fo the Vivitar Vivi Cam 35 Digital Camea
Posted on Jan 29, 2008
  • 2,985 Answers
Read the Manual Sexy just sit down and read the manual
Posted on Jan 22, 2008
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Photography
What does the E mean on screen and u can't take pictures. know one knows even change film and barreries
E means that the film hasn't been loaded properly. Is the instructional manual for the camera, if you read through it it should tell you how to properly load the film.
May 11, 2011 | Pentax IQZoom 105WR 35mm Point and Shoot...
What film does this camera require and where can I get one at? I recently just received it as a gift however I don't know a thing about how it works nor how it functions! Please help!
You probably should take it into a camera shop and ask for help. For the price of a film they will get you started, show you how to load it, and so on.
Oct 25, 2010 | Olympia GM8426 Film Camera
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
Disney princess camera
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
How to put film in the camera
Hey buddy5000,
The process to load film into your camera is as follows
1. Turn the camera on and make sure the frame counter reads 0 if it doesn't there is probably film in the camera.
2. Press the film door release button and slide the release downward.
3. Place the new film cartridge in the film cartridge chamber and pull out the film leader until it reaches the red dot on the bottom right side of the film chamber. Make sure the holes on the lower edge of the film engage the teeth on the sprocket.
4. Now close the back door and the film should load automatically and# 1 should appear in the frame counter, and if it does not then the film is not loaded properly.
I hope this helps!
Go Ahead. Use Us.
Jun 10, 2008 | Minolta Maxxum 5000 35mm SLR Camera
Loading film
After further investigation and because I can't keep my hands out of things I now know that the camera body is defective and that the shutter is jammed. It will only release with assistance. I was loading it correctly.
Apr 17, 2008 | Photography
Film Advance
You rewound the roll to fix the camera and now you want to advance over the exposed film to get to the unexposed part? Not a problem, just put the camera to full manual and load up the film, now cover the lens with the lens cover and go into a dark closet and start shooting and advancing until you get to the unexposed portion of the film, there you go. You know you can get 24 exposures of 35mm film for 99 cents and the 99cent store?
Feb 15, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Film not loading properly
The lines could be scratches in the negatives.
Have you looked CLOSELY at your negatives with a magnifier to see if the scratches are on your film?
And when you say "Serviced", do you mean "cleaned" also?
If you have scratched film, then return it to the place you got it serviced/cleaned and let the owner/manager know that you just had it serviced there and it's scratching your negatives.
If you have an automatic camera, this bit below will be of no help.
Assuming that your camera is a manual loader, it may be that you aren't putting enough film into the take up spool for it to catch.
Try putting a little more film into the take up spool when you are loading the camera, and MAKE SURE that the holes in the film LINE UP with the film sprockets.
Then after you close the film door and start advancing your film, look at the film rewind knob, if it isn't turning while you are winding in film, then your film hasn't caught in the take up spool.
Another way to tell if your film is advancing is to shoot a test shot, and then advance the film, and then lightly turn the rewind knob a bit.
You should be able to feel the tension of the film if it is loaded correctly.
Feb 13, 2008 | Nikon FM10 35mm SLR Camera
Vivitar ViviCam 35 Digital Camera Logo
87 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
