The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
