Question about Yamaha RX-V661 Receiver
Yamaha RX-v661 7.1 Receiver
My reciever plays for about 30 minutes then goes into safe mode for about 1 hour. Then it does it all over again. I cant even get into the movie before it goes down. Checked all wiring and it is clean no shorts. Help Please
  • 2 more comments
  • wannaskyline Jan 22, 2008
    Area is very breathable. This is a brand new receiver why would I need to buy a fan for it. Shouldn't it be built to work? It hasnt even worked hard yet.
    Yes its wired properly. Thanks
  • Anonymous Mar 16, 2008
    Yamaha rxv2300. my amp keeps turning off for no reason.There is no pattern of when it will turn off.Most times you can turn it on straight away and it will be fine,but sometimes it will turn off straight away.Put into repair shop and charged me to fix it,but still has problem,took back and they said couldnt find any problem.Rang customer service at yamaha australia and they said to check speaker wiring,checked out and no problem.It sits in a well aired position.Its driving me crazy and out of warranty.Whats next.
  • wannaskyline Mar 16, 2008
    Got the new reciever back and still doing the same thing. Changed impedence and still does it. Triple checked all the wiring. Could I have used to big of wire?
    Novelist:
  • 236 Answers
3 possibilities
1.as mentioned your environment, inadiquate cooling. But that depends on how load you are using too.
2. An overloaded output, impedance check please. set it to lowest impedance. If it was working normal before, can you recall if sometime in the past you have posibly overdriven your speakers and your amp turned off? Check your speaker or crossover network for possible short.
3. Very rare case but a persistent trouble if already present in the unit of Yamaha AV system CPU. Grounding problem of your main amp board and controller board. More than twice i have replaced the CPU but still turns off. I have modified to shunt the main board directly to the ground, since then the system went stable. In another model or unit with cooling fan, i have modified to fan-on circuit to advance fan activation. Because in some cases, the air produced by fan not enough to cool the heat sink when it is already hot. What i did was to set the fan to go on earlier even before it becomes hot. No harm done withg the unit, it is stable.
Red
From Yamaha service.
This is not certified solution by Yamaha but my own. Even Yamaha could not find a solution, replacing boards etc... still the same.
Posted on Mar 19, 2008
  • Redentor Rivera Mar 19, 2008
    the system has to be modified... I dont know in your place if Yamaha service will dare modify. it is brand new, but i was from Yamaha service too and i make my own modifications for them, sor customers. You brought it for service and when returned still doing the same, obviously they did not find any trouble, but it was working well with them otherwise they will not give back.
    Did you get the sets of speakers from them too? did they suggest to you the speakers to match your system/ 661 is a medium power amp only but main amp is highly biased for best quality, power but the result is overheating. maybe a little modification will do. But as you said brand new unit so Yamaha should be on top of it.
    Reden
    redrivera0314@yahoo.com
Could be overloading your circuit and the receiver goes into safe mode to protect itself
Posted on Feb 12, 2008
    Sergeant:
  • 395 Answers
On the audio processor board there is a bad battery capacitor (super cap). this board is the upright board where the audio jacks are located. the cap is C633 a .047F 5.5 volt. you must remove this cap and clean under it and arround it. this cap leaks it's electrolidic fluid that intermitantly shorts the foil arround it. replace the cap with a new one.
Posted on Feb 06, 2008
  • Robert Johnson Feb 06, 2008
    if the unit is new, set the impedence to 6 ohm page 93 of the manual will tell you how. dis-regaurd the "super cap" that is a problem of a different receiver. sorry about that!
  • Robert Johnson Mar 16, 2008
    two things about these sysems (since I have been a yamaha repair man for ever). 1: speaker impedence these systems are set for impedence of 16 ohm per speaker (who has 16 ohm speakers?) set the impedance to the 6 ohm setting. 2: check the speakers if the speakers have a short "SHUT DOWN" is the result. check for broken or torn surrounds on the speaker basket (woofer).old speakers are the most likley culpret. push the cone in and out gently if you feel any friction or scraping sound coming from the speaker then it is bad. tweeters don't have this kind of problem because they are some what issolated. phasetec speakers are 6 ohm so make sure the impedence is set correct. check all speakers for short. if you have a dought about the speakers unplug them one at a time untill you find the culpret.
All speaker wires on right termanals good plug
Posted on Jan 22, 2008
    Genius:
  • 1,067 Answers
Over heating then is it in a breathable area buy fans on ebay for it plug into the switch on ac outlet from off ebay
Posted on Jan 21, 2008
Yamaha RX-663 Powers down
It sounds like it's going into safe mode try testing the resistors just after the power supply you will probably find one or two at fault
Feb 15, 2014 | Yamaha RX-V363 Receiver
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Hi I'm George. my yamaha rx-v795ards after an hours playing or when a loud sound comes, it turns off. you turn it on and then goes off again
Hi George,
Here is something that you can do , or have someone to assist you.
Disconnect all speakers.
Power it On, If it turns On completely , Be glad.
Put back speaker one at a time to find the cause.
If for instance , it doesnt work ....
It may need servicing.
Let us know what you find out or post back if you feel you can DIY.
Oct 06, 2012 | Yamaha Rx V795a 5.1 Chan 425 Watt Home...
Hi, have Yamaha RX-V467 receiver hooked up as follows: directv sat to Yamaha receiver via HDMI. blu-ray to receiver via HDMI. Receiver to Sony lcd tv via HDMI out to TV. Have 2 problems when watching TV...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Yamaha-RX-V467-Receivers-review-manual/id/23658bh533/t/1-2/
1) How is it with FM? That -35dB may be normal for this receiver. My old Pioneer is exactly like yours, inaudible at -50, whisper-quiet at -35 on all sources. But it will still crush my skull if I want it to.
2) Page 72. Press STRAIGHT to toggle out of Straight decoding mode.
Apr 24, 2011 | Yamaha RXV467 Receiver
I have an Yamaha RXV440. It goes into protection mode instantly.
The Yamaha repair shop evidently couldn't find the failed component(s) and/or cold solder joints causing it to go into protection mode. Sony equipment has similar problems related to protection mode.
Mar 21, 2017 | Yamaha RX-V440 Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Dec 29, 2007 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
291 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
