Canon imageCLASS D760 All-In-One Laser Printer Logo
Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a paper jam below the sliding lid -
There is a paper jam below the sliding lid on the last set of rollers - only visable only where the paper comes out. It will not pull out. Is there a way to reach that area?
Anonymous
Level 2:
Sergeant:
  • Expert 240 Answers
  • Posted on Dec 14, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
240
Questions
0
Helped
86954
Points
595
I suggest opening the right cover to remove paper jammed internally. There is a lengthy document at Canon support for your model: (you need to input your problem into the search box - ie. "ERROR LCD: Paper Jam" and click Search button).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9437
2answers
Paper jammed light flashing but no jammed paper
Switch off the printer at the power wall socket and back on again and press the printer on button (if it has one). This resets the printer so it can go through it's normal start up routine and detect any remaining faults.
If the light is still flashing then open up the printer lid to access the paper feed roller and manually turn the roller to check for any small pieces of paper causing the fault.
Close the lid and then fully remove and reinsert the paper tray to reset all the paper sensors.
Printer keeps saying paper jam
unplug printer, lift lid, check rollers throughly, look to see if any piece of paper is stuck in the roller or cogs, remove
plug printer in, turn on
lastly, remove all paper from tray and put half as much in
hope this works and good luck
1helpful
Says have paper jam when there is no paper in the printer
see what you gotta understand
is that right next to the
rollers that pick up the paper
are paper sensors so if those
sensors have been damaged take
a cotton swab dip it in water.
clean the rollers where the
paper is taken in from and
also clean the carriage rod
along which ur cartridges
move(metallic rod).
Remove any loose paper from the input tray. Press the Power button (c01345237.gif ) to turn off the product.Disconnect the power cord from the back of the product.
  1. Gently pull any jammed paper out of the rollers in the back of the product.
  2. Rotate the rollers upward to make sure that they move.
  3. Clear any paper jammed paper from inside the duplexer.
    1. With the wheels facing toward you, unlock the duplexer by pulling back the gray levers on each end of the duplexer.
    2. Open the duplexer lid.
    3. Remove any paper from inside the duplexer.
    4. Close the duplexer lid.
    5. Lock the duplexer by pushing the gray levers up and forward until they snap into place.
Before reattaching the duplexer to the back of the product, follow these steps to clean the paper rollers to remove any debris, dirt, or paper scraps.
  1. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward with your fingers to clean all the way around.
  2. Allow the rollers to dry completely.
  3. Reattach the duplexer to the back of the product. Gently push the duplexer forward until it snaps into place.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
  6. Load paper in the paper tray.
  7. Try the print job again.
    • If the error message displays again, proceed to the next step.
    • If the pages print successfully, you do not need to continue troubleshooting.
Follow these steps to clear the jam from the automatic document feeder (ADF).Remove all originals from the document feeder tray.
  1. Lift the cover of the ADF.
  2. Lift the ADF mechanism.
  3. Gently pull the paper out of the ADF mechanism.
  4. Lower the ADF mechanism.
  5. Close the ADF cover. Press down until the cover snaps into place.P
  1. ull out the main input tray.
  2. Slide the paper-width and paper-length guides to their outermost positions.Insert a stack of paper into the main input tray with the short edge forward and the print side down. Slide the stack forward until it stops.
  3. Slide the paper-width and paper-length guides inward until they stop at the edges of the paper.
  4. Push the main input tray back into the product.
  5. Pull the output tray extender towards you, as far as it will go
  1. Press the Power button (c01346625.gif ) to turn the product off.
  2. Disconnect the power cord and the USB cable from the product.
  3. Unplug the power cord from the wall outlet.
  4. Reconnect the power cord and the USB cable to the product.
  5. Plug the power cord back into the wall outlet.
  6. Press the Power button (c01346625.gif ) to turn the product on.
Under one year old pixma mp150 all in one/ changed ink cartridges/error code E2 / saying no paper ????
I have had a MP 150 Cannon Printer with a E3 paper jam code..when NO visable paper jam is present ! Your No paper problem may be as a result of similar issue due to a small piece of paper stuck in the roller assembly out of sight. TRY this, Turn printer off wait (10 seconds) or more then turn printer back ON and listen for roller assembly to turn the ROLLERS and then FORCE FEED
a sheet of paper into rollers until it PULLS paper through and SEE if any scrap of paper comes out with the sheet !! If this works you should see that it clears the code. and resets your printer.
Let me know if this works. Phil at [email protected]
GOOD LUCK !
3helpful
2answers
Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
Lift lid to continue printing
OK, Based on the information provided I think I can offer a solution. They are getting open and close top cover and the unit will print a few pages and stop. I will assume the machine is indicating paper jam (although not confirmed) and no paper is in the machine. A maint. kit was recently installed.
The problem is likely the separation clutch.
The clutch is located in the paper tray (tray 2 and tray 3 if installed) just to the right of the roller.
Heres the test:
Remove the roller and the clutch. The clutch will slide off the shaft after the roller is removed.
reinstall the roller.
Run a paper path test for the tray you removed the clutch from or just print something multi pages.
If the machine prints more then the few pages at a time without giving the error we have solved the problem.
You need a Sep. Clutch.
NOW PAY ATTENTION:
You may get a jam error printing without the clutch installed BUT there will be paper in the printer. This is because without the clutch the machine may feed more than one sheet at a time. but if the paper is making it into the machine the clutch is the issue.
Hope this helps
Brother lc900 paper jam
the problem is with roller.
Paper feeder jams and crinkles the paper up
there is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
1helpful
Canon Imageclass D880 all-in-one
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
old marine
old marine
ZJ Limited
ZJ Limited
