Kodak Easyshare C813 Digital Camera Logo
Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the memory card located - Kodak Easyshare C813 Digital Camera
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Dec 14, 2009
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
934180
Points
7369
The card slips into a slot behind the batteries. Open the battery compartment door and you'll see the slot. Need the operating instructions for your camera? You can download them here:
http://www.kodak.com/global/en/service/publications/urg00775toc.jhtml?pq-path=11889
Nokia 2690 no show memory card problem solution
Hi , Follow the following steps to unlock the memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
Nov 12, 2012 • Cell Phones
My memory card is corrupted what shall i do
If you have important files on your memory card,try this procedure,might be recover by an application which can retrieve all data by all means,
http://www.fixya.com/support/r9410003-recover_accidental_corruption_mmc_or
If it's not possible anymore,you need to format your memory card with the use of your computer and a multi media card reader.Locate the drive which the memory card is inserted,then right click then look for the format option,then format it.
* If this method does not work,might need to replace a new memory card
* or check the switch located at the knob of the memory card slot.might already damage and neet to replace the switch
* or it can be memory card ic that needs replacement and possible to bring it to any mobile service shops near you.
Good day...
2answers
Not able to use camera, message indicate that memory stick not available, when card is already inserted.
Check your camera settings if the the SAVE location is in your memory card. Also check and locate your phone settings or file manager if your memory card recognizes the phone.If not readable then you have a problem on your memory card, or ever try another card and check if it's working.
best regards,
Jun 25, 2011 • Cell Phones
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
How to copy photo from phone memory to memory card?
DEAR SIR,
YOU CAN DO That BY FOLLOWING THIS METHODS:
1.start your phone and access main MENU and then find out FILE MANAGER icon from menu,it may be located in application folder or settings folder.Their will be two sections one PHONE MEMORY and MEMORY CARD ,first locate your photo files (it may be in phone memory - images) and select your destination photo files,and select OPTIONS -ORGANISE -COPY TO FOLDER and select MEMORY CARD (you can copy it to any folder of the memory card)
2.by simply
MENU - FILEMANAGER - select - PHONE MEMORY- IMAGES- PHOTO FILE -OPTIONS - ORGANISE - COPY TO FOLDER- MEMORY CARD -ANY FOLDER-and press -COPY - icon
plese follow this order and make a smile
thank you
1helpful
Trying to locate where to put a memory card
Hello, was wondering if you meant memory card or memory chip. If it is a chip, it goes next to the other memory chip in the slot. Must be right memory or the motherboard may fry out.
If it is a memory card, you must have SD-MS slot. If you do not have the slot, you can by one and hook it up to the pci slot.
Sonyericson k750i cannot save images
Hi
Firstly have you a memory card inserted?
If yes, is there any problems reading files from it?
If yes, remove memory card and re insert, it may just be connections dirty?
If no memory card inserted chances are your camera settings are set to save to memory card.
To change this start the camera and go to settings/options.
Look for default save location. If it is set to save to memory card and you dont have one, that would be the reason why it is not saving images. Either install a Pro Duo memory card or change default save location to 'Phone'.
Hope that helps?
Fujitsu-Siemens Amilo Pro V2040 Laptop memory locations?
Sorry, This laptop only supports one memory card slot upto 1.7GB
Why does the camera Ready light glow steady red?
The cause and solution may include one of the following: The camera internal memory or card is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The camera processing memory is full. Wait, and resume picture taking when the light turns green. The card is read-only. Change the storage location to internal memory or use a different card.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
