Question about Consew 199R-2A Sewing Machine
Timing I have a camsew machine. It has a coged belt and I took the belt off and now that I have the belt on I think I have it out of time. How do I time the top gear to lowe gear? It has a tag on it that says 125, I cant find any other #. I see an Arrow on the lower gear but I cant find any thing on the upper pulley? please help? thanks gmann
  • gmann55 Jan 23, 2008
    Hey it worked great. Thanks so much. gmann
The belt seems to be too loose
Belts on sewing machines have what is called a "tensioner." That is a piece--usually at the bottom of the belt--that has (generally) two screws, also generally Allen screws, that should be loosened, but not removed. Once loosened, you can increase the tension on the belt, but it should be adjusted JUST ENOUGH so that the teeth grab. Be very careful not to tighten too much; if you do, you can burn out a bearing over time.
Mar 06, 2014 | Singer 4830
Where is the timing belt on a Singer 3820 located
The timing belt is inside the bottom of the machine.
Dec 07, 2012 | Singer 3820 Mechanical Sewing Machine
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
E2 error message
I have brother sewing machine CE 4000, it became jam, I opened the machine & tried to rotate it with hand, I took out the belt, it became easy to move, again fixed the belt, but now it does not turn on, may be the timing of belt has disturbed, it shows Er2, how to fix it.
Dec 09, 2011 | Brother CE4000 Computerized Sewing Machine
I have a sew easy SM 1000 sewing machine and am having problems threading it. I do not have a manual. Please help.
same problem, found the issue and can't fix. When I took the bottom of the machine off, I quickly found the "Lug Belt" BADLY worn and broken. Making the timing slip and thus making the top line not get caught on the bottom line. Can't find the lug belt for this machine online
Feb 03, 2011 | Euro-Pro 7500XH Mechanical Sewing Machine
Hi, This is regarding a Singer sewing machine, model no. 7466. I think the drive belt has slipped off the lower pulley, because the needle bar moves freely when the handwheel is turned toward the...
You probably have to coax it a little at the seams, just don't be too forceful, like try a real thin knife to see if it gives a little on the sides and top. So remember be gentle when trying to get it apart
Nov 17, 2010 | Singer 7466 Mechanical Sewing Machine
I have Singer 5040c machine i was cleaning this machine it was working fine before, but machine is breaking needle all the time ,i can't sew anything, i just remove belt from bottom part cleaned it...
Your machine needs a professional to fix your timing and tune it up. You may have messed up the timing when you took off the belt. It is worth getting it fixed.
Sep 19, 2010 | Singer 5050 Mechanical Sewing Machine
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
Consew 199R-2A Sewing Machine Logo
42 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
