Question about Vizio L32 32 in. LCD HDTV
Vizio sound sounds like a short. certain stations lose sound for a second here and there
4 Suggested Answers
  • 123 Answers
SOURCE: Vizio tv seems to have trouble with volume certain
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 01, 2011
SOURCE: Certain stations have no sound
I had a similar problem and it had to do with the new analog to digital converter box. I called the cable company (Comcast in my case) and they said to select the 'language' button on the remote and it fixed the issue.
Posted on Mar 29, 2009
SOURCE: Vizio 32lcd turns itself off on certain station
Do a full channel scan again. It should solve that problem.
Posted on Jul 03, 2009
  • 178 Answers
SOURCE: No Sound on certain stations
Check to make sure your tv is not in SAP, if one is in spanish this is a big clue.
Posted on Sep 03, 2009
0 characters
1 Points
Do you have vizio E420vse schematic?
sounds If the set gone into stand by mode. You could try switching it from standby mode. that's if you haven't damaged board.
check power to board while pressing standby.
Jan 20, 2015 | Vizio 42 in. LCD TV
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Flat Panel Televisions
My vizio tv is practically brand new as of christmas, when a movie or even tv is on the voices are very soft and the music or background noises are EXTREMELY loud, so I am always turning the volume up and...
I had this problem with my previous TV (Syntax by Olevia, an off brand). It only happened to me on certain channels, and for certain shows. What is happening is the TV station is broadcasting the audio in Dolby 5.1 format. For some stupid reason, the TV is playing the background speakers (effects) instead of the speaking parts. You get a little bleed-over of the voices into the back speakers, so voices are there but really quiet. Unfortunately my TV didn't have any surround sound options to fix this.
See if your TV has a surround sound option. Otherwise, you will need to connect the TV sound output to a surround sound system that can properly decode the audio channels.
Feb 06, 2011 | Flat Panel Televisions
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
My vizio makes a popping or clicking sound
The sound from my vizio 22" HDTV is not working properly when I attach it to my cable TV.
Sep 29, 2009 | Flat Panel Televisions
Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
Check to see if you have the audio in SAP mode ! If it is turn it off, or to stereo.
Mar 26, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
Buzzing sound on Vizio Plasma TV
likely supply failure or shorted pannel driver. u should be able to unplug the pannel boards from the power supply. if the buzzing stops than its the pannel boards otherwise its supply.
Dec 05, 2008 | Flat Panel Televisions
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio L32 32 in. LCD HDTV Logo
109 people viewed this question
Top Vizio Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Vizio Flat Panel Television Expert? Answer questions, earn points and help others
