Question about FireLite (USBFLB80) Hard Drive
Center Pin External Power Polarity
SmartDisk FireliteUSBFLB120 - What polarity is the external power center pin? + or -? I have universal power supply, not enough power from USB pin on PC. Need external power. Unit and manual do not indicate C+ or C-.
  • 1,006 Answers
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Posted on Feb 17, 2008
I have a very old Maxtor external 200 GB hard drive. I can not find the power adapter for it. On the label, a part of it rads 12V 2A - does that's mean I need to look for a 12 volt, 2 amp power adapter?
Depending on the power adapter, you might be able to pickup one at Radio Shack..
If it is a single pin plug, check near the power adapter jack to see if it shows you polarity of the
center pin, which will either be "+" or "-" Take this information to your local Radio Shack along
with the voltage and amperage requirements
Feb 06, 2011 | Computers & Internet
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
Radio Panasonic RF-4900 - no power
Just spent the afternoon with an RF4900 with a power problem. The set was intermittent. Found on the back of the set where the ac plugs in, there is a switch that is ingaged when the ac plugs into the set. If the ac cord is old it might not be engaging this switch when the cord is plugged into the set. The switch controls ether battery power or ac power.
Mar 20, 2009 | Panasonic Audio Players & Recorders
Voltage/polarity of power supply for NEC pcmcia 4 port USB2 card
If you KNOW it is 5 volts then you only need to make sure that the amp is higher and never lower. Higher amp only means it can work without getting too hot. But the VOLTS MUST BE precise. For polarity it is MOST common to have the center pin PLUS and outer NEG/GND. When I fix laptops and put the powercord wrong nothing happens. When I get it right then lights go on on PC.
Oct 31, 2017 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Want to know polarity of Zip 100 DC power supply.
I just connected a new power supply to my zip 250MB, with the center pin as positive - and it worked out well :-)
Dec 18, 2008 | Iomega U.S. Power Supply Drive
Wireless phone
normally the center pin is positive
Apr 27, 2007 | Uniden UIP-1868P IP Wireless Phone
Ac adapter 3.0 V polarity
Center pin is positive, and um Zap! Cheers!
Apr 17, 2007 | Vivitar ViviCam 5385 Digital Camera
FireLite (USBFLB80) Hard Drive Logo
279 people viewed this question
Top FireLite Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
