Question about Bassett Parson Ridge Crib
Missing pieces I bought this crib from somebody online and finally got it put together and found out that its missing a piece. The steel pole, rod or whatever that goes on the railing so that the rail can be let up and down is missing. Do you know where I could purchase another one cause the one side of the crib is flemsy cause its not connected.
  • marfotsch1 Jan 23, 2009
    I think these are called toe trips...don't know what they look like and do n't know my model number. Are they universal..will they fit any Bassett crib? [email protected]
How do i put basset crib together do the rods have springs on to and bottom of the rod? How do you attach the springs to the head boards and how do you keep the sides up its been 20 years now we have a new granddaughter hope someone can help
Posted on Jul 19, 2008
    Scholar:
  • 58 Answers
This is from Bassett's website.
Bassett recommends that all cribs manufactured prior to 1972 be replaced because improved safety features were instituted that year. If your crib was made in 1972 or after, replacement parts are available from Products America at 1-800-772-1041. If you are unsure when your Bassett crib was made, Bassett urges you to replace it.
Link to Products America
Posted on Jan 29, 2008
6ya staff
SOURCE:
Ive got a 10x10 lawn and party gazebo made by summer rite ... do you know where to get instructions ?
Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
_1430.jpgTake
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieces to each end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with both silver metal fasteners on the #3 poles facing outwards)
Then connect each end of the combined poles to the end piece.
Now lay out the final set of poles (# 5 and 6), but only connect the #5 pole to the end piece first, all around the gazebo.
Okay, now we want to start adding the actual canopy. Start by pulling the corners down at each pole joint then velcroing the tarp underneath in the middle of the 3-4-3 combined pole.
Now it is safe to connect the next set of poles (#6) to the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each pole and then connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needed though I tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
May 30, 2011 | Camping, Backpacking & Hiking
As we were putting crib together (brand new) we notice that there was a piece missing off the railing where it goes up and down to put baby in. How could I find this part?
immediately call the manufacturer and tell them. sometimes in factories pieces are left behind by mistake. in addition contact the store where you purchased the brand new crib one of those two should be able to help.
Jan 10, 2010 | Simplicity for Children Aspen 4in1 Crib
Need one crib rod for a 04540
Products America does supply crib rods, as well as many other crib hardware items. Please call 800.205.9642 or 800.772.1041 for direct assistance.
Oct 04, 2009 | Vintage Lullaby Nest Crib
Child Design Crib Replacement Parts
I did the same thing I took the smallest side piece into my local do it yourself hardware store and the found the pieces for alot cheaper than the manufacture.
Jul 26, 2009 | Childesigns Shelby Crib
Plastic pieces missing from the railing on the crib
please contact [email protected] if you need detailed instruction on christina model 8996crp. i have the manual and i would be happy to help you out.
Jul 12, 2009 | Simplicity for Children 8994W Crib
Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
Pottery Barn Sleigh Crib Assembly Instructions
We recently put together a PBKids sleigh crib bought on craigslist. the original owner gave us all the old bolts. We actually put the side that DOESN'T say "push" on first. When attaching the "push" side - the one thing we figured out is that you have to fit that side UNDER the rails that are visible on the sides and then pull UP (rather than going down, you have to pull up to fit it in.) that said, the original owner did not give us any bolts/stops to put in the sides that would keep the rail from falling completely to the floor when you push the drop side in. anyone else have suggestions?
Aug 10, 2008 | Baby Gear
Missing parts
You should be able to take those pieces out of the bottom ends of the crib rail bother than that I'm not sure I have been looking for the plastic pieces for the top of the rail that you squeeze together to lower the side and I called the company and they said they don't carry any parts for this crib anymore. I wish we could all get these cribs together and switch pieces that we need to make at least some of these cribs work its pretty bad. Oh well I hope this helps you.
Apr 21, 2008 | Cosco 2 in 1 10-185-WHO Crib
Bassett Parson Ridge Crib Logo
440 people viewed this question
Top Bassett Baby Gear Experts
Vincent G
Vincent G
ROB
john h
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
