Question about Hitachi RAS-09UH Air Conditioner
Outside unit has frozen
My outside unit has considerable frozen content on the vents and will not operate. What can I do?
Thank you,
Lee
  • 236 Answers
Check your air filter and evaporator at the indoor, and also the outdoor condenser coil if clean, be sure that the outdoor has no obstruction to both front and back of the unit. If dirty then clean both indoor and outdoor. If clean let the ice melt by turning of the unit and unplug the power cord or off the circuit breaker to reset the error if error is present. And on the unit again and observe if icing is present when unit is operating. If icing is present after 10 to 30 min of operation then the unit is under charge.And while unit is operating adjust your thermostat to higher temp. to check if thermostat is operating normally. If the outdoor will trip off after the adjusting the temp. then your thermostat control is ok if not then the thermostat control have a problem.
Posted on Jan 21, 2008
Just installed furnace, turned on heat, everything running good. Water seen on floor under unit, don't know source, considerable amount of it.
thats your answer the steam from wet clothes turn to water if you havent connected the outside vent iit will be the reason there is water on floor
Oct 14, 2014 | Dryers
My Amana PTAC allows outside air to come through the entire unit (everywhere). I think that maybe the outside air vent, which is closed) is not secure. Would there be a problem with screwing it shut w
If you can get to the fresh air vent, and it is open, plug it by any means necessary, as long as it's safe. It will not affect the overall operation of the unit.
Oct 22, 2017 | Heating & Cooling
Wanted to know if somehow this model can be charged and used outside of a vehicle
No the unit can not be charged and used outside a vehicle. It needs a continuous power source.
Thank you,
Lee
Nov 29, 2010 | TruTech LMD-5702RT Portable DVD Player
NOTED THAT REFRIGERATOR COIL IS FROZEN. WHAT COULD THAT BE?
Welcome to FIxYa.com
Clean condenser and check fan for operation
Regards, Lee Davidian
Thank you for using FixYa,com.
Oct 23, 2010 | Whirlpool Refrigerators
My outside a/c condensing unit's fan runs, but inside vent air is not cold. compresser may not be running. inside vent air was cold last week. Janitrol ckj361ab is model # of outside unit.
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Jun 17, 2010 | Heating & Cooling
Does HP Laserjet Printer 4250n consists of Deuplexer Unit for two sided printouts? Vyankatesh
This is an optional accessory you can purchase. It's price varies considerably depending on where you purchase it from.
It's model number is: HP Q2439B
Thank you,
Lee
Dec 11, 2009 | HP Office Equipment & Supplies
Copper lines outside are visibly frozen. Unit is
you have a restriction of air ,change filters and clean coils that should do it make sure nothing is blocking return vent
Aug 22, 2009 | Heating & Cooling
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Kenmore All in One?Dryer Heat Minimal?Excessive Dry time
be sure vent to outside is not plugged or partially block be sure vet tube in back is not compressed flat or folded basically be sure you have good air flow to outside to take the moisture to the outside away from the clothes
Jun 06, 2008 | Kenmore 45081 Front Load Washer / Dryer
Hotpoint RLA54 fridge
Under charge of refrigerant is one of the ice build up in the unit, but try the defrosting method and after all ice are gone operate the unit and check vents if air is present. If no is air present inside the unit may be the blower motor inside has a defect. Its either stock up, burned, or worn out bearing
Mar 04, 2008 | Refrigerators
Hitachi RAS-09UH Air Conditioner Logo
337 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Marvin
Marvin
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
