Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stations are not clear
My programs/stations cannot be viewes clearly even after repositioning the antenae
Anonymous
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Dec 13, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
54791
Points
645
There's not much can do for a poor signal apart from buy a better antanae with a higher dB rating.
Have lost satellite coverage due to money restraints, How to connect antenna to tv.
Please provide the following information.
1. what country are you in
2. does your country have digital or analog air television stations.
if your country does not have analog television you may not have options for a clear signal, you need an antena outside the house if you do not have a clear line of sight to the tv transmitter for analog television.
Also it may be a good idea to do a channel search from within the television menue.
HD radio stations are not coming in clear
see if there is a local/distant selector on your unit. It will make it so your radio will only let you find very strong stations, also check your antenna connection to make sure it is pushed all the way into the connector and is clean of corrosion or anything that could keep it from making good contact inside of the connection, you can use steel wool or scotchbrite pads on the surfaces to ensure a good connection.
My digital tv will only pick channel 10, abc and sbs, even though it used to pick all channels?
U trying to pick up all free AIR DTV tv stations wright?Yes.This problems u have a weak airial antena.Buy a better antena like a Digital antena or a roof antena for hook up.Tries again,will pick up all DTV free AIR tv stations.
How do I program the tv to use without cable?
1.Power on the television and press the "Menu" button on the Olevia TV's remote control.
2 Choose the "Programming" option to view all of the Olevia setup options.
3 Choose the "Channel Program" option, then select either "Antenna" or "Cable" (select "Cable" when using a satellite receiver).
4 Select "Start" and the Oleiva TV scans over all the stations it receives. Once complete, is stores the information into its memory bank, so when you attempt to change the television station you only see programs that come in clear onto the TV.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Unable to tune free view channels........... help !
Get a better Antena,like digital antena or a roof outside Antena to get better reception.Go to ur tv menu goto SETUP pick AIR and scan all the DTV free air programs stations.
2helpful
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
