Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
File transfer size limitation for LACIE HD
Files bigger than about 4GB cannot be transfered to my LACIE 300GB HD.
It says there is not enough free space in the drive which still have some 200GB left. Is there way to work around this threshold thing? Thanks a lot!
  • 871 Answers
Hi
can i suggest that you use winrar to divide the file size of your file that you want to transfer to your lacie. this might work.
download winrar @ majorgeeks.com
but if you LACIE still says that it does not have any disk space left...i would suggest that you reformat the HD instead. but make that a last resort...
hope this helps
Posted on Jan 23, 2008
6ya staff
SOURCE:
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
Lacie won't register that it's empty
Click Start
Right-mouse click My Computer
Click Manage
Double-click Storage
Double-click Disk Management (Local)
Right-mouse click on the 60GB partition
Choose Delete Partition
Click on the 300GB of "unallocated" space.
Create a partition that "spans" the 300 GB.
Format the new partition.
Jan 16, 2010 | Computers & Internet
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
Cannot transfer files that are greater than 4GB
The lack of free space iis on your internal HD not the external. Whenever transferring files from one drive to another, you are acturally making a copy of the file to be transferred and sending the copy to the new drive. If your internal HD is nearly full, you can try to Cut and Paste the files to the external, or clear up more space on your internal b/4 tryiing to move the bigger files. Best of luck.
Greg
Jul 09, 2009 | Western Digital 500GB My Book World...
LaCie 200GB HD is now ''read-only''. Recommends reformatting.
>> my computer could not repair the hard drive
It seems that the disk-drive is "dying", and the "table of contents" on the hard-drive has become corrupted, and automated attempts to "repair" the corruption have failed.
>> the hd is being offered with limited functionality, basically read-only.
Yes. Take this as a "hint" that the disk-drive is about to "die".
>> It recommends that I back-up the info elsewhere
Good advice. Take the advice.
>> and reformat.
This may help -- it will identify any "bad" spots on the hard-drive, and will either permanently avoid using those bad spots, or it will allocate a "spare" track on the drive to be used as a substitute for the "bad" area.
However, even after doing this, I would not "trust" the device to be a "reliable" backup for my important files. Like a well-used chalk-board in a classroom, the disk is getting "worn-out".
If it's still under warranty, exercise the warranty.
If the warranty has expired, replace it.
Apr 22, 2009 | LaCie Computers & Internet
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Cant download large files to my book
Try converting from FAT32 to NTFS. That should take care of the problem. Check out http://support.microsoft.com/kb/314097/EN-US/ for the XP instructions.
Oct 23, 2007 | Western Digital My Book Essential Edition...
LaCie Porshe 500GB
if it's a fat32 formatted disc, then it won't recognize a 4GB file. that's the nature of fat32, i'm afraid.
Sep 06, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
226 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
