Question about Nintendo Wii Console
Wii has no video or sound.
Unit turns on, disc loads and eject but no video or sound. please help.
  • kingbutters Jan 21, 2008
    I Connect all the cords in the right places, but i have no video just sound?
    really weird need help?
  • ursdbz Jan 22, 2008
    I am sure that I didnt get the conenctions wrong. It has to do with Wii itself. I am not using the original power supply. but I am getting a new 1. that is the only think i can think of. if it is not the power supply than it must the Wii. thanks.
    Problem Solver:
  • 10 Answers
Hi, double check the rca jack cables that are red and white are connected to an input for the tv and not accidently hooked into the output connectors. Sometimes the tv manufacturer puts them right by each other. Hope that helps, Also depending on the tv there maybe more than one input set of connectors close together, so if you have the video in the line 1 connector but the audio in the line 2 connector you'll have picture but no sound. Try switch line inputs while the Wii is on and in a screen that is making noise and see if you have sound in any other line in(source) setting. Jay
Posted on Jan 21, 2008
  • dlagwa Jan 29, 2008
    Another thing you can check is the pins on the connectors at the back of the wii and the wire plug in. Make sure they are all lining up correctly. Otherwise, yup might have a bad one. Good Luck. Jay
My discs wont load
You could find the manual on the internet by google. Im afraid that it's possible that it possibly broke the disc drive or the part of the drive that automatically loads and ejects the disc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
May 17, 2012 | Nintendo Wii Console
My daughter crammed several discs in the wii at once. My wife removed 3 stacked out of it. Now it won't accept a disc past about 1/3 of the way in. Makes the sound like ejecting, but no others will come...
The loading/ejecting mechanism needs to be reset. It involves opening the Wii, and turning the gears on the side of the optical drive until the they are in the "Unloaded position". Turn the larger gear with the "belt" on it counter-clockwise until the plastic guide on the side is fully seated in the lower position. This should allow the Wii to take in a disc. If you don't have the know how to open and service your wii, post the problem on craigslist, and you should find someone willing to help you with your issue! Hope this helps!
Feb 26, 2011 | Nintendo Wii Console
When i try to load a disc it says to eject the disc and turn the power off
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
http://store.richspsxparts.com/wiiredvddr.html
Jul 22, 2010 | Nintendo Wii Console
Wii turns on but will not read any disc.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
Hope this will help...
May 27, 2010 | Nintendo Wii Console
The Wii keeps ejecting the disc and we can't play on it
With the Wii Console vertical, the discs should be loaded with the shiny side to the left. If you are loading like this and all discs are being ejected, then you very probably have a problem with the Wii Console.
To ck into repair go here:
http://www.fixya.com/ThreadView.aspx?thid=2204194&prdid=618512
May 12, 2009 | Nintendo Wii Console
Wii disc not ejecting
I am sorry to say but you will have to disassemble the unit to get to the dvd unit and remove the disc manually
Here is a little diassembly guide.
http://forums.lovingwii.com/nintendo-wii-hardware/425-guide-disassemble-nintendo-wii-video-pictures.html
Hope this helps!
Feb 13, 2009 | Nintendo Wii Console
We are getting an error message everytime we load a disc
Try the following options.
1:) Soft Reset:- Press the reset button on the Wii console For 2 seconds.
2:) Hard Reset. :- Unplug The Wii Console For 5-10 Minutes. As once unplugged it resets itself.
3:) use a CD/DVD Based laser head cleaning disk, to remove any dirt/dust from the laser unit.
Thankyou For Using Fixyas Free Forums.
Mike @ compurepair.
Nov 30, 2008 | Nintendo Wii Console
Games eject
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Aug 16, 2008 | Nintendo Wii Console
Problems loading games in wi
sounds like the laser is going on the dvd player, you can try to clean it.
Feb 21, 2008 | Nintendo Wii Console
Wii disk not ejecting
Jan 23, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
2,090 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
