Question about Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite 1405 - Power problem
I was using my laptop when I received a pop-up box saying something like "Change your battery immediately or switch to AC". Well, I do not use my battery. It is always on AC. After about 5 minutes, the laptop screen when completely black.
- The green light on the front was a solid green for 1 day. Now it is blinking green
- The yellow light is blinking indicating that I need to change my battery.
- Periodically, when I press the "on" button, the red Toshiba word will show, and I will get 2 lines of normal script, that show every time the laptop is turned on. Then everything goes black.
Does anyone know what I need to do to fix this problem
Don
  • DKWebb Jan 23, 2008
    Found the problem. I have a power bar surge protector. It has 4 plugs. The plug that the AC adapter was plugged into was "bad". The other 3 plugs are ok. I used a different plug. The laptop now works ok. By the way, I purchased a new power bar. It was a learning experience though.
    Thanks for the help
  • 689 Answers
Hi Don
Although symptom is showing that AC Adaptor is not working as its not providing power to the unit. I will suggest you to perform some basic troubleshooting steps. Check if outlet is working if not check with known working outlet. If you have a multimeter you can the output of the AC adaptor.
Also you can perform full power cycle and component discharge. Take the battery out and disconnect the AC adaptor press the power button and hold about 7 seconds. After that put the AC adaptor in and test again.
If issue persist take to nearest Service center check with known working AC adaptor. After that I believe you will figure out the best solution.
Good Luck
Posted on Jan 21, 2008
My Toshiba Satellite 1405-S151 is indicating that it is receiving power, when I push the power button it indicates that it is powering on. The screen does nothing :-( help?
if your TOSHIBA laptop is doing this then check the RAM(memory)
if the problem persist check the Processor,
Likewise If it continues use WorkStation on the VGA Chip;
thats all
Dec 21, 2010 | Toshiba Satellite 1405-S151 Notebook
Am not able to get drivers for Thoshiba satellite 1405-S151 laptop
sanathanchan,
Here is the website for driver support for your model of Toshiba Satellite:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=191872&rpn=PS140U&modelFilter=1405-S151&selCategory=2756709&selFamily=1073768663
Hope this helps.
-S
Oct 19, 2010 | Toshiba Satellite 1405-S151 Notebook
Can not figure out how to use projector with laptop.
maybe you need make a configuration in settings f2 or f12 to avaliable the vga port out
Sep 16, 2009 | Toshiba Satellite 1405-S151 Notebook
Toshiba 1405 s151 will not turn on. the green light for the plugin is on. i let it sit overnight but it will not do anything when i hit the power button.
remove the battery and power .CLEAR THE bios by removing the small battery on the mainboard for 10 hurses and power it on.
Aug 05, 2009 | Toshiba Satellite 1405-S151 Notebook
The battery will charge but will not turn on unplugged
This seems like a bad battery again. Take it back witht he laptop and have the shop or store test it. This is not a software issue...
Mar 05, 2009 | Toshiba Satellite 1405-S151 Notebook
Manual
To download Toshiba Satellite 1400/1405 manual, please click the link below:
Thank You
Nov 10, 2008 | Toshiba Satellite 1405-S151 Notebook
Hard drive removal? Satellite 1405-S151
How to Add or replace your Hard Drive
1. Turn off the notebook, remove the power cord & battery
2. Use a screwdriver to remove the two screws that hold the hard drive compartment panel in place. (on the bottom of your laptop)
3. Gently lift the panel and slide it out.
4. You'll discover that the hard drive is bolted to the panel with four screws. Use the screwdriver to remove the screws. Separate the hard drive from the panel.
5. Slip the new hard drive into the panel and align the screw holes. Replace the screws.
6. Put the panel back into place and make sure it locks
in securely.
7. Replace the two screws that hold the compartment panel in place.
Oct 10, 2008 | Toshiba Satellite 1405-S151 Notebook
Toshiba laptop
Appreciate the "Ask Me".
On your post, pls try:
  • click on Start, Control Panel, Network Connections;
  • right click on Local Area Connection;
  • click on Properties;
  • click on Configure Button;
  • click on Advanced tab;
  • highlight Connection Type, in the Value box, select Auto-Negotiation;
  • you may be asked to reboot.
You could also try the 100 Base Tx Full Duplex or the 100 Base Tx Half Duplex.
It would seem that the orange led indicates a 100mbps connection while the green is for 10mbps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Toshiba Satellite 1405-S151 Notebook
Want a manual
You can download user guide/ manual here:
Toshiba Satellite 1405-S151 manual
After downloading this PDF file, open it and click the print option. Then, a dialog box will appear, in which you can select how many pages or which page to print.
Thank You
Sep 03, 2007 | Toshiba Satellite 1405-S151 Notebook
Toshiba Satellite 1405-S151 Notebook Logo
173 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
