HP Pavilion a705w PC Desktop Logo
Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset BIOS on HP Pavilion a750w
I have an older computer I am trying to fix. It is HP Pavilion a705w. I am getting a BIOS check sum error stating it is detecting media in the floppy a drive. Think I need to reset the BIOS. Cannot locate it on motherboard. Do you know another way to correct this problem, or how to reset the BIOS?
Anonymous
Level 3:
  • Master 1,959 Answers
  • Posted on Dec 13, 2009
Anonymous
Master
Level 3:
Answers
1959
Questions
Helped
1215314
Points
7500
Fastest way to reset BIOS is to remove the CMOS battery (looks like a large watch battery on Motherboard) for 30 minutes. After you replace the battery, the BIOS should reset to default. If further problems arise involving the BIOS, it's possible the CMOS battery is bad.
Gerardo Diaz
Level 1:
Problem Solver:
  • Contributor 16 Answers
Gerardo Diaz
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
8052
Points
31
Estart your pc pres te F8 repided ley till the bios screen shows there you can fix your problem
Manual & schematics for hp pavilion a705w
HP Company makes no guarantee of any kind regarding the substance, including... directions and finish the first windows until you find the desktop. Refer to. "turning on... Here is the easiest fix to the HP computer.
My error message is NTLDR is missing press cntrl + alt Del to restart I fixed this a year ago in the bios menu. I forgot how to do this. I don't have my Windows XP CD, but I didnt need this the last...
hello, when it happened on my computer it was the bios that was somehow set to boot from the wrong disk. It happened after I had to reboot after a hang, so it hadn't been shut down properly. Hope this helps!
nicam49
5helpful
HP pavilion A750w starts up, but doesn't seem to go to POST, or at least there is no video once I turn on the machine. Used original, and newer monitors. Replaced onboard video with EVGA GEFORCE FX5500...
Hi there you need to make sure the monitor is properly connected and make sure you install the drivers for the new video card.If you still have the problem you should open the computer and check the memory by taking it out and put in into another memory slot on the motherboard.If you have more than one memory in the computer please take them out one at a time and restart the computer if that does not work you should replace them you new one that is compatible with your computer.
Logs on and than suddenly logs off
Look on your motherboard beside the bios battary you will see a jumper with 3 pins move the jumper to the last two pins for 5 second then put it back that should reset it
I have done system recovery, now my hp pavilion a705w will not boot!!
Check in the bios if the Hard disk is booted as priority in the boot sequence and remove all cds in your drive....
Otherwise you will have to start the recovery again
My hp pavilion a705w will not read 8 gb micro sd cards. I get an i/o error.
you need to get the reset disk for windows or open up the computer and wiggle it
1helpful
My HP a705w is stuck on the blue logo screen.
1)unplug all the peripherals from the computer,press the power button and hold it,then connect the peripherals.
2)open the tower and try to reseat the ram and the memomy slot.
3)try to go to BIOS screen,if it gets stuck while going to bios,shut down the computer,disconnect the sata cable of the harddrive,try to boot the computer to bios without the hard drive connected,if it goes to bios properly with the harddrive cable disconnected,that means hard drive has gone bad.motherboard is alrite.
1helpful
HP Pavilion a705w PC Desktop\Ethernet Controller driver
obtain the driver from cd/dvd that was included as you purchased your desktop and try to check if the driver supports with the operating system you are using now. for example the driver available in your cd/dvd is only for windows xp and your operating system you are using now is windows vista of course driver not installed. try to download from internet the driver that are suite to your unit model and current operating system this can fixed your problem or else downgrade your os tha can support the driver that are available from your cd/dvd.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
