Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model no. 110.26842691
My washer is about 10 yrs old and is constantly ripping and tearing large items like sheets, towels and my husbands shirts.
I do not use bleach and I do not use hot water - All my sheets and towels have turned into rags. I had someone come out and they said that my agitator was fine. Can someone tell me why this is happening and what I should do?
    New Friend:
My washer will not take water. There is no delay for water to fill up and the machine starts to wash immediately. All cycles work normally.
Posted on Apr 23, 2010
Your agitator may be fine but how is your washer behaving is it trying to perform two acctions at one time like spinning and agitating at one time the tarnmission may be locked up
Posted on Jan 21, 2008
6ya staff
SOURCE:
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
Why is my kenmore washer shredding sheets?
Check the drum for any Sharpe edges or splits also check the activator for the same . Something in side may have a rough edge to cause this .
Apr 25, 2017 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
My Sears Kenmore, 2 years old washing machine is ripping clothes
If this has a paddle,check it for a sharp edge,also make sure it is not loose, the top cap should be able to be pulled off to see the locking
bolt,and you can check to see if it has loosened.
Feel everywhere on the inside of the washer for a edge that might be catching your cloths. You can also try the gentle cycle and see if it does not rip them.
You did not post the model# ,so I have no clue what style it is.
Apr 07, 2009 | Kenmore Washing Machines
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine woes
Buy a new machine. You have used it well. After Two repairs I suggest replacements
Since you are not paying for water I would suggest a top loader. I have been Happy with Kenmore (Whirlpool in Kenmore skin) or look at a Speed Queen Top loader.
Dont over load your new machine, learn what it can and cant handle.
Best of Luck T
May 28, 2008 | Whirlpool LSR7333 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
525 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
