Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-in-One--Ink printout problem
I've had several problems with this printer. Paper jams and newly refilled cartridges read as low or empty...after visiting this website, I see I'm not alone. This new problem has me stumped. I printed out note cards (two on one 8-1/2" sheet) and then a 4"x6" photo. Both times the first 1/2" of printed ink came out in pink tones when it was supposed to be in blue tones. After that the rest of the printout was correct. I checked the Help section of the printer and there was no solution. Anyone have any ideas? I'm wasting paper and ink!
  • Anonymous Jan 29, 2008
    I'am unable to reset in levels on my Lexmark 4350 printer,do I need a chip resetter for this printer or am I doing something wrong.
  • Glenn Starnes Jan 31, 2008
It may sound stupid but try cleaning the steel rod that the cartridge runner runs along, with a little luck this may help the situation I know it has for others. It did not help me though. I have a Lexmart P for POXY 4350 that has had little use, but I have just tried to re-fill the black cartridge and kept getting iether the1203 or 1103 error code. I tried everything bar a complete strip down and it still does not work so I went and bought new cartidges and the problem has not gone away I am therefore stuck with £24's worth of rejected cartridges and a visit to Tesco for a new Epson.
Posted on Mar 02, 2008
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
The front window on my lexmark P4350 allways says the cartridges are empty even when they are full please help
Are you still able to produce printouts? Try to re-seat the cartridges in the printer.
Please note that a refilled cartridge will not be able to report its ink level.
Oct 12, 2011 | Lexmark P4350 All-In-One InkJet Printer
My ink was showing low so i just bought lexmark combi ink from tesco L111 number 34 and 35 and yet printer is still showing ink as empty why is this printer is p4350 model
use the menu on the printer and select the printer options-> ink cartridge-> new ink cartridge and the ink meter should be reset.
Remember that the printer does not actually read the amount of ink in the cartridge it makes predictions about the ink levels based on the number of pages printed on the cartridge.
Jun 30, 2011 | Lexmark P4350 All-In-One InkJet Printer
After refilling Lexmark ink cartridge, ink levels donot show full. Reset ink level?
When you refill your cartridge, the cartridge will no longer be able to register its ink level.
Apr 06, 2011 | Lexmark P4350 All-In-One InkJet Printer
Problems with Lexmark X2550. I have refiled for the first time a lexmark 28 cartidge. Now I have paper jam all the time, I cannot print and I don`t know what to do. I blame the cartidge, because before...
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 03, 2009 | Lexmark X2550 All-In-One Printer
Ink levels of refilled cartridges
Refilled cartridges usually do not show the correct ink levels. As far as Im aware there is no way to adjust that readout on those cartridges.
Thanks
Aug 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X8350 jams (and other problems) after ink cartridge refill
You have a paper jammed in the path or there is something blocking the path, try to look inside carefully.
Apr 29, 2008 | Lexmark X8350 All-In-One InkJet Printer
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Ink cartridges
I think the cartridges cannot be reset to full once they have emptied once. If you choose to refill yourself you may have to live with the low ink warnings all the time.
Oct 02, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350
I am also experincing this problem after refills. Older Lexmarks you had the control to tell machine it is a new cartridge.Had cartridges refilled in stores deticated to doing nothing else but refilling new ink.Still will not read full??Have no idea as to what to do.
Mar 30, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
159 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
