Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solo-baric L7
I need a wiring diagram
  • 5 more comments
  • jasonstiles Jan 22, 2008
    4 ohms 1 speaker 1 coil
    im trying to wire up this speaker but dont have a wiring diagram
  • tricky 59 Apr 23, 2008
    i would like to know how to connect the back wires of my 12'' l7 kicker so they could soud lauder?
  • courtneydad May 02, 2008
    I need to know how to hook this speaker up
  • MEATL3753 Sep 18, 2008
    I have 2 12 solo baric subs and they are wired to a 4 ohm load how big of an amp can i put on the speakers if they are bridged they are 750 rms and 1500 watts peak
  • Anonymous Feb 02, 2009
    i have (1) dual voice 4 ohm solo baric L7 into 4 ohm load how do i wire it
  • Anonymous Apr 27, 2009
    how to wire a 4ohms l7 15 kicker to a power acoustic 4000 watt mono amp
  • 185 Answers
Ok here is a real pdf manual from kicker and please rate me
www.kicker.com/06/tech-support/manuals/manuals/02SL7TechManualV2_0.pdf
Posted on Sep 26, 2008
    New Friend:
  • 101 Answers
Wat r u trying to do? how many ohms is your amplifier thier r many ways to wire subs depending on ohms of amp,number of speaker,and how many coils they have .this is extremely important.wiring them wrong will cause exopensive damage to speakers or amp.get back to me and ill help you,. im good with car [email protected]
Posted on Jan 22, 2008
  • Anonymous Jan 23, 2008
    http://www.rockfordfosgate.com/rftech/wo...
    this should help
  • Anonymous Jan 24, 2008
    DID THAT SIOLVE YOUR PROBLEMFOS GATE HES EXTENSIVE DIAGRAMS,IF SO CAN I GET A FIX IT RATING?
    IF NOT GET BACK TO ME AND ILL GIVE U MORE INFO
I have 2 kicker L7 12s 2 ohm, i need to get them to one ohm.then if i can .5 ohms at the amp
Posted on Mar 27, 2008
2 Suggested Answers
6ya staff
SOURCE:
toppertighe
  • 29 Answers
SOURCE: i wanna know if a 1500.1 amp good for 2 15'' kicker L7 solobarics
yes but you might get better results from it if you wire it for use on 2ohms
Posted on Oct 13, 2009
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
Oct 30, 2015 | Kicker Car Audio & Video
I have one solo baric hooked up in a 4 ohm series to a 1000 watt kenwood amp that I've tried hooked up normal and bridged at 4 ohm. When I turn it up the sub cuts out. I've looked up a bunch of...
hello, first i would find out what ohm your sub is cause you may think your setting it up for 4 ohm you may be going 2 ohm or 8 ohm. here is the link to for wiring solo baric. http://kicker.com/wiring_diagrams
Aug 24, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I cant remember how to install the kicker 12 l7
Your subwoofer is single or dual voicecoil? And what amplifier Make/model are you putting it on?
Thanks!
Nov 04, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Need new spider
go to Kicker.com...they should have what you need.
Jul 25, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
1,464 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
