2002 Toyota Tacoma Logo
Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installed battery - to + (Reverse)
2003 toyota tacoma Installed new battery reverse - to + ro + to -. Turn over but won't start
Anonymous
Level 2:
New Friend:
  • Expert 160 Answers
  • Posted on Dec 13, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
160
Questions
0
Helped
65042
Points
350
IF U REVERSED POLARITY, UR PROBABLY GOING TO HATE URSELF!!! RED WIRE IS ALWAYS + AND WHITE WIRE IS ALWAYS -. WHEN THERE IS A BLACK AND RED WIRE PRESENT, RED IS ALWAYS + AND BLACK IS -. CONNECT UR BATTERY WIRES PROPERLY AND HOPEFULLY EVERYTHING WILL WORK FINE, IF NOT, CHECK UR FUSES...IF THEY'RE GOOD, THEN THE COMPUTER MOST LIKELY GOT FRIED...
My 2004 Toyota tacoma automatic will reverse. However when the engine gets up to around 2000 rpm the truck seems like it kicks out of reverse and just starts reving up. Let off gas in reverse and rev down...
Could be a few issues, why was the tranny replaced? If the old one was failing badly and had any metal bits in the fluid etc, and you reused the same torque converter, that may be part of the problem. Was the system thoroughly flushed out before filling it back up? If not, same issue as torque converter is possible. If a new converter was used, was it filled up before you installed it? After sitting for so long the pump seals could have dried and the pump could be leaking, causing all kinds of problems.
Having trouble getting my 2003 Tacoma, auto trans to shift into 4x4. Any suggestions?
is this part time or AwD
if part time 4wd try ice or dirt.
PT is not for dry pavement.
ive no idea which 4wd transfer case in in this PU>
2answers
2003 toyota tacoma won't start
What was checked/tested ?
Fuel pressure at motor & spark cranking?
Battery seems fine based on what kind of testing?
Won't Start
Won't Turn Over
Have to get your thoughts around what you say
2003 Tacoma Intermittent Starting problems
If your able to drive to Autozone,they will check your alternator and battery for free.
Car only starts in reverse and only drives in neutral
Sounds like a cable to the transmission is not adjusted up right, and/or the neutral safety switch is not adjusted right, if this applies to your Toyota Corolla.
1helpful
How do i replace the key ignition on the column of a 1995 toyota tacoma pickup, two wheel drive, 4cyl.
disconnect negative battery cable.remove upper & lower steering column covers.disconnect switch wiring connector. turn key to acc. release retaining pin through small hole in the side with a paperclip,slide key & cylinder out.re-assemble in reverse order.
3helpful
Replace starter
Disconnect the battery, then crawl under the truck and locate the starter, remove the plug going to the solenoid (small brown lead w plastic clip) . then the power wire that goes from the battery to the main starter terminal (12 mm nut) locate the 2 starter bolts 14 mm and unbolt the starter and remove. install in reverse order. ON the 4 wheel drives you may need to remove the skid plates over the bottom of the engine to access the starter.
Truck dies but engine keeps running. battery or alternator?
You need an alternator....well unless your belt came off or got very loose. The truck continued to drive because the battery had enough juice left to run the ignition system, but after you shut it off there was no where near enough to turn the engine over or possibly even run the starter. The battery will have to be charged and a new alternator installed.
Hope this helps.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
