Washing machine not working
Washing machine not draining, not rotating
  • vvhasyagar Jan 21, 2008
    Right now leave it sir, a local technician is looking at the problem
  • Anonymous Aug 31, 2008
    not spinning and no lights are on
    President:
  • 1,294 Answers
Take out your exit hose from behind the machine, try to drain at floor level. Be prepared for a lot of water. Then switch on the machine and press "end of cycle"; try the door after a lapse of 2 minutes. Ref to manual. Not good to 'sir' here, we are at your service! Free!!
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Jan 21, 2008
Why does my candy grand o washing machie say 08 and stop working
If the code actually is E08, there is a problem with the motor speed sensor. The motor may be rotating at high speed for a few seconds, slowing down, and stopping or there may be no rotation at all.
Feb 24, 2017 | Candy Washing Machines
Drum won't spin on Tricity Bendix AW 1260W washing machine. What do I replace? Is it worth it? Machine is 7 years old.
Hi just food for thought,I normaly fix my things that are brocken,but I was told by a washing machine teck that the life span is usuely 5years,some times you get lucky and other times it gose wrong and you keep throughing money down the drain,I wish you the best and hope it works out for you if you deside to try and fix it.
Nov 21, 2016 | Tricity Bendix Washing Machines
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
How does clutch assembly work on lg wft 1022 tp
ITS BELT DRIVER,WITH WASH MOTOR,,, ITS CONTROLLING BY DRAIN MOTOR,,BY THE DRAIN MOTOR CLUTCH FULLING & RELEASING,,,AT THAT TIME ONLY WASHING,,SPINNING,RINCEI TIME DRUM ROTATING ,,,
Jan 19, 2014 | LG WFT1071TP Top Load Washer
Bosch classixx washing machine won't spin. It fills up and washes - does not drain, does not spin. I have manually drained it and checked the plug - nothing was trapped. Ran the machine again - fills,...
Check the filter if clogged clean it or if not check if pump is functioning. Sometimes pump can' work bse of coins stuck in it or rubber bands from pockets.
Dec 08, 2017 | Bosch Washing Machines
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Water will not drain from the machine. We washed a bathmat with a rubber backing and it came apart. Something is clogged, but the owner's manual just says to restart the DRAIN program. We've done that...
Draining problem is very common in Bosch washers. However, it is very easy to fix.
1) Remove the white circular plate, located on the bottom left. Push a small screwdriver or needle through it and simultaneously rotate the plate clockwise.
2) Open the drain valve. Rotate the circular black handle counterclockwise. Beware of residual water.
3) Clean it. Re-assemble in reverse order.
Thanks for contacting fixya.com
Nov 24, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Oct 11, 2008 | Bosch Washing Machines
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
